CEL P0301 '01 LX 131K miles M/T 1.7L
Old Mar 27, 2015
wehrd1's Avatar
wehrd1 is an unknown quantity at this point
I searched the forums, but wanted to give this particular cars issues and when/how they came about.
this is my spare car, and it has been in use for about a week, as my daily driver (100mi r/t commute), while my real daily driver (92 Civic VX 5spd h/b, 329K miles) is having some body work done. Thanks to a white tail deer strike that buggered the front fender into the tire, and when i hit a bump in the road, would scrape the tire.
This '01 was running like a dream since put back in use for the last week. Is on 1/4 tank of fuel from 2nd fill up since put back in use. (it sat for several months unused until last week) Stopped at a traffic light this morning, and i noticed rough idle. Drove an add'l 5 miles to work, and CEL flashed. Just barely saw it, as it occurred as i was parking in the lot.
Left work, CEL was on solid, except at idle, while at stop lights then it flashes, until under load, then goes solid. Had the code pulled - P0301.
I'm a TOTAL novice, but my mechanic SIL is looking at it tomorrow. Please point us in the right direction to try, before I start throwing unneeded $$$ at it.
I also found the 7th gen online service manual, and have downloaded it for his use, jic it's needed.
Thanks guys!
Old Mar 27, 2015
Re: CEL P0301 '01 LX 131K miles M/T 1.7L
Got freeze frame data to go along with the code pull?
2001, with how many miles?
Last valve adjustment was_____?
Compression test, then evaluate and assess results?
Old Mar 27, 2015
wehrd1's Avatar
hopefully my SIL has a tool that can capture freeze frame data. if so, will post results when he stops over to check it for me.
131k miles
i have no idea when/if last valve adjustment was done.
Old Mar 27, 2015
Checked plugs yet?
Swap plugs and coils to other cylinders to see if the miss moves?
If it's missing at idle and it's an extremely consistent miss then a compression test would probably be in order.
Old Mar 27, 2015
wehrd1's Avatar
Checked plugs yet?
that's what he said he was going to try first, swapping to see if code moves.
if his driveway diagnostic points to or eliminates a more involved issue, then he'll be taking it to his shop.
thanks for your input thus far. I've pointed him to this thread. He worked on my daughters 95 DX and did a head gasket R&R, when it blew, and had head machined, and did a oil pan gasket replace. so he's not a civic novice anymore.
hopefully with the link to the 7th gen service manual, he'll work through this as well. he'll get his trial by fire because my family has 5 civics. 2 5th gens, 1 6th gen, 1 7th gen and now a 9th gen. we also have 2 honda gl1800 goldwings.
i think we should be in a Honda commercial
Old Mar 27, 2015
test would probably be in order. .
Sounds like he should have a handle on the situation fairly quick.
Old Mar 30, 2015
wehrd1's Avatar
what are the specs on cylinder compression on this car? he can test them, but would like to know spec
He's doing this on his own time, is why the thread waits until he can get to it.
Thanks!
Old Mar 30, 2015
Specs? Pffft.
How about real world numbers: Using my own (trusted) equipment and using my methods, I expect to see about 180 PSI or higher.
Old Apr 1, 2015
wehrd1's Avatar
He didn't have to do a compression test. he R&R'd the coil pack on cyl#1 and R&R'd all the plugs with the NGKs and the car runs great! no code on the 6 mile trip home.
hopefully, it will continue to do so
Thanks all
thana
Jun 15, 2020 07:05 PM
juror
May 26, 2015 06:35 PM
Fastfebur
Apr 26, 2015 11:57 PM
smmahan
Apr 15, 2015 08:17 PM
htowncivicEX
Jan 21, 2002 11:48 AM
