Cannot get new lower arm on!!!! please help
Old Jan 19, 2015
sandro881's Avatar
sandro881 is an unknown quantity at this point
Hi everyone,
I am having major problems getting my new lower suspension arm on, Im just not able to attach it to the ball joint.
I have had a mechanic come round to have a look and he was not able to do it either, thinks that maybe the ball joint is broken and wont flex enough towards the arm.
Does anyone know why this may be, had similar issues, or know how to fix it?
Thanks in advance for any help!
Old Jan 19, 2015
Re: Cannot get new lower arm on!!!! please help
My guess: The axle has been overextended, the inner CV joint came out of its cup and a roller or two are now out of place, and the CV joint can't "plunge" into its cup now?
Old Jan 19, 2015
sandro881's Avatar
Thanks so much for the reply! Do you know how i can go about fixing this?
Old Jan 19, 2015
Other thought: Was the ball joint replaced?
I'd peel the boot off and reassemble the joint. But that's me, I don't want to buy an axle.
Old Jan 19, 2015
sandro881's Avatar
No, the ball joint was not replaced.
Do you think someone with limited knowledge like myself would be able to do this?
Old Jan 19, 2015
mikey1's Avatar
no, no offense
Old Jan 19, 2015
sandro881's Avatar
Originally Posted by mikey1
no, no offense
I appreciate the honesty!
Old Jan 19, 2015
So logically, the ball joint should not be the problem here.
Not thinking this AM..... First I'd try to manipulate the joint back together while it's all in place on the car... Taking it all apart would come after that.
Old Jan 19, 2015
sandro881's Avatar
Ok thank you so much for the advice, I will try that. Im guessing I just need to twist and push it around a bit to see if it will go in further?
Sorry if this is a really stupid question
Old Jan 19, 2015
Understanding how it's built inside before you begin might be a big help.
Old Jan 20, 2015
sandro881's Avatar
Hi thanks,
I have tried twisting it about and pushing it in ect, but no luck in getting the lower arm in still.. I have booked in for a mechanic to come and inspect it on Friday..
Does anyone have any other suggestions about what could be wrong?
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
bashea
Sep 15, 2015 04:59 AM
