P1362 Code after Low Oil and Over-heating
Old Oct 1, 2014
alpinegroove's Avatar
alpinegroove is an unknown quantity at this point
99 Civic LX.
Over the weekend, the temperature gauge was nearing the red zone.
Coolant was low in the radiator and the oil dipstick was nearly dry. My fault...
Today, CEL is on with P1362 code, TDC sensor no signal.
1. Is it safe to drive the car this way?
2. Can it cause further damage?
3. Anything I could check before taking the car to the shop?
4. Could this code be related to the low oil level and heating issue from a few days ago.
I did add coolant and oil as soon as I discovered it.
Thank you.
Old Oct 2, 2014
Re: P1362 Code after Low Oil and Over-heating
Probably unrelated. Maybe influenced, but not directly related.
TDC sensor is inside the distributor.
You can ohm check the sensors, but replacement (if necessary) will involve a replacement distributor.
Warning: Aftermarket distributors are crap.
Check out this thread, the OP runs into a distributor code at about post #3, some troubleshooting follows: https://www.civicforums.com/forums/2...old-crack.html
Old Oct 2, 2014
Thanks. I'll take a look.
What about driving the car in the meantime?
Old Oct 2, 2014
Correct the lack of oil and coolant problem first.
Figure out where and why those fluids disappeared.
See if any damage occurred from the overheat event (blown head gasket, warped head, etc.). Damage may not be immediately apparent.
Old Oct 2, 2014
I corrected the low fluid levels immediately upon discovering it.
How do I know if it actually overheated? The dial did not reach the red zone, but it was getting close.
How do I know if I have blown head gasket or warped head?
The car seems to be driving fine so far. I have deleted the code and am waiting to see if it comes back on.
I just don't want to cause additional damage by continuing to drive the car. Is that an issue?
Old Oct 2, 2014
That's close enough for a scare. Damage can occur before the gauge maxes out. (Think of the red area as the "waaaay too late" zone.)
Pay attention to coolant levels in the radiator and reservoir, and pay attention to the tamp gauge. If the levels stay stable then you're probably ok. (If the radiator goes low while the reservoir gets overfilled, that's a problem.)
Search here for blown head gasket, read about how a 7th gen acts when it has a blown head gasket. Yours may be similar. Find the sticky about overheating, there's a lot of info in that thread.
ok
As long as you keep oil in it and it doesn't overheat again, it should live until something else breaks... Unless the distributor takes a poop or something.
I can't predict the future LOL
HTH
Old Oct 2, 2014
Interesting. Before this happened I noticed that coolant levels were dropping in both the radiator and reservoir. I couldn't detect a leak anywhere.
I had a number of heating incidents, and every time noticed that coolant was low in both radiator and reservoir.
The radiator was replaced (by me) last year, and I just assumed that there were some air bubbles in it, although I tried to bleed them out.
Old Oct 3, 2014
Well yeah, any time the radiator is allowed to get low it's more likely to overheat the engine.
Several lesser overheats can be just as bad as one big overheat.
If there is no external coolant leak found, then it almost has to be internal leakage.
Since coolant is disappearing, I'd pressure test the cooling system to try to encourage the leak to show itself, then Look harder for external leakage and evidence of leakage, maybe bring in some flashlights, a real car hoist, and a fresh set of eyes...
If that yields no results, maybe figure out some head gasket testing.
Old Oct 3, 2014
Thanks. I'll look into it.
mattdoc
Mar 14, 2017 12:10 PM
RIPSAW
Nov 6, 2015 04:36 AM
docmartin14
Jul 30, 2015 11:26 AM
jakeconnor
May 5, 2015 07:30 AM
dooner24
Apr 14, 2015 07:51 PM
