8th Gen 2006 - 2011.
***Please Help!*** Ignition Coil nut broke!
Old Jul 26, 2014
matt cheshire's Avatar
matt cheshire is an unknown quantity at this point
I can't find anyone ore anywhere to help so please pardon my ignorance on where to ask this.
I was replacing my spark plugs on my 2008 Honda civic LX and the black painted hold down nut broke clean. I am looking for a new thread (I don't know what the part is called). Where can I order the parts to fix this because my dealer won't help without charging a large fee.
Here are pictures of the broken part.
ID:	86913   Click image for larger version
ID:	86914   Click image for larger version
Old Jul 26, 2014
mikey1's Avatar
Re: ***Please Help!*** Ignition Coil nut broke!
how the hell did you ever break that off?
those nuts only need to be hand tight, maybe a little snug with a wrench
if you broke those i would assume the repair is above your level of expertise, take the car to an independent shop, not the dealer,
you should be able to drive the car to a shop without that nut
Old Jul 26, 2014
Put a wrench on this hex and see if it will spin out.
It must be turned counterclockwise to remove.
Then you will have to go to the dealer and buy (probably special order) this part number: 12216-RNA-A00 (bolt, spark plug coil)
And the nut is # 90207-RAA-A10
The set will probably run you about 6 bucks plus tax (assuming you only broke off one of them).
PS, I agree with mikey. If you managed to break that off, you may want to get outside help so you don't cause further damage.
If you break off this one, it's gonna get expensive in a hurry.
Rlss
24
Feb 26, 2016 09:42 PM
Uan
Aug 23, 2015 03:03 AM
Dani1993
Jul 24, 2015 09:02 AM
emich
Jul 20, 2015 08:42 AM
Civic65
Jul 19, 2015 10:13 AM
