Out of ideas. Need help
Old Jul 20, 2014
Hayden_Fourroux's Avatar
Hayden_Fourroux is an unknown quantity at this point
Hey all. I have a 97 EX (D16y8) that warms up quite a bit while stopped. About 3/4 of the temp gauge. Now I have tested the fan, motor, relay and all are working. I replaced the radiator about a year ago and just replaced the rad. cap. Now ive noticed that my coolant in the overflow boils, so i replaced the rad cap. Still "overheats". So what else could it be? Coolant is also just over a year old. Thanks in advance guys!!
Old Jul 21, 2014
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
Re: Out of ideas. Need help
You've probably checked this but the thermostat?
Maybe air bubbles can cause this, not sure.
Old Jul 21, 2014
Ok, I did test the T-stat. It does open and close. It appears to open around 180 degrees. Does that sound about right, because on the T-stat its self it says 78 degrees Celsius which is about 172 degrees F. Also oil is not milky, I just checked it this morning. I guess maybe the only other cause could be air in the cooling system??
Old Jul 21, 2014
180 is fine.
That doesn't rule out anything.
And how would 'air' get in there?
Old Jul 27, 2014
nsxvtec's Avatar
nsxvtec will become famous soon enough
check for a bad head gasket
Old Jul 30, 2014
Headgasket is all good. The coolant in my overflow boils after a drive. So i think I am loosing pressure somewhere. Radiator cap was replaced 2 weeks ago. So loose hose maybe?
Old Jul 30, 2014
What did you do to test this?
Old Jul 30, 2014
No test. I heard it so i opened te hood and saw coolant boiling in the overflow
Old Jul 30, 2014
No test.
So you are just assuming the head gasket is good then?
Old Jul 30, 2014
It was replaced a year ago. Plus oil isnt milky or anything. My bad thought you were talking about overflow
Old Jul 31, 2014
That doesn't mean it's good.
Not a typical symptom for that engine.
A head gasket can fail in any of a dozen different ways.
What I think you are seeing in the overflow is not boiling.
There isn't enough heat in the reservoir to boil water.
You are seeing the venting of excess pressure from the radiator into the reservoir. The issue is that it is not venting liquid, but "air". How low is the radiator?
It could be the result of boiling within the pressurized cooling system, or you might be seeing the venting of excess pressure caused by combustion leakage from a head gasket leak.
That's 2 possibilities.
You have to figure out what it really is, and why.
HTH
Old Jul 31, 2014
rujoesmith's Avatar
rujoesmith is an unknown quantity at this point
Sounds almost exactly like what happened to my car when I had a bad headgasket. Try taking the rad cap off while its cold, then start the car. Give it some gas and see if it shoots coolant out of the radiator. If it does then it probably a crack in the gasket allowing combustion gasses into the coolant.
Old Aug 9, 2014
Thanks, I will give that a shot
BigG422
Sep 9, 2015 10:59 PM
MamaBear2015
Aug 27, 2015 09:29 PM
mbloor
Jun 27, 2015 03:42 PM
mbloor
Jun 27, 2015 11:45 AM
