8th Gen 2006 - 2011.
2010 honda alarm reset
Old Jul 20, 2014
kings322's Avatar
kings322 is an unknown quantity at this point
The key fobs for my wifes car recently stopped working. wont open or close the car. she has the lock the car with the key on the drivers side. The car is fitted with a remote start that works just fine. Is there a way to reset the alarm on the car so that the keys will work again?
Thanks
Old Jul 20, 2014
Re: 2010 honda alarm reset
Questions:
BOTH original equipment key fobs affected?
Is the remote start system a genuine Honda accessory, or is it an aftermarket system?
Red LED light on each fob, does it illuminate every time you push a button?
Does the panic button make the car horn honk?
Do the power locks work with the lock/unlock button on the drivers switch panel on the door?
Have you checked for blown fuses in both fuse boxes?
Door ajar light on as if a door isn't shut?
Does the 'key in' chime run with the drivers door open, even if there is no key in the ignition?
If the system thinks a key is in the ignition, it disables the keyless lock functions completely.
If it thinks a door is open, it will not lock (but can unlock with the fob).
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
alexkharden
Apr 23, 2015 07:13 PM
Linda0818
Apr 23, 2015 11:30 AM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
