Sandwich plate leaking and Fuel Filter leaking
Old Apr 18, 2014
Lordsin's Avatar
Lord Sin
Lordsin is an unknown quantity at this point
As the title says both are leaking. Fuel filter leaking from the bottom and top of the screw on bolt to the feed hose that goes into the injector rail.
Sandwhich plate leaking oil I tried to tighten the bolt all the way down to make it flush with the block and the oil filter could not be tighten or started.
Old Apr 19, 2014
Re: Sandwich plate leaking and Fuel Filter leaking
Got pics?
Got new seals?
Old Apr 19, 2014
Lordsin's Avatar
Lord Sin
No pics the leak is a small stream. Bought a new fuel filter and it was the same. I'll take some tomorrow morning
Old Apr 22, 2014
Lordsin's Avatar
Lord Sin
Changed the fuel filter outlet hose that goes into the fuel rail, new banjo bolt with aluminum washers. Removed the sandwich plate and added a few washers so the plate is flush and clean against the block.
dpru
May 26, 2015 07:01 PM
Shakzhussain
May 17, 2015 12:03 PM
Ninetyatecivic
May 9, 2015 07:48 PM
green01civic
Apr 29, 2015 01:36 PM
superstanko
Apr 28, 2015 04:38 AM
