94 civic hatchback radio
So I bought this hatch about a week ago and when I brought it home the radio worked, it didn't have a bracket to hold it in so you can pull it out and slide it back in. Well the car was pretty wired for subs and I gently pulled the radio out and made sure the plugs and remote wire were connected and they were, I put the radio back into the slot and it shut off. I ran through the wires on the adapter and the original wires and everything seemed fine. Fuses were good in the fuse box and in the radio. What is holding me up from listening to the radio?
Re: 94 civic hatchback radio
Check the fuse under the hood. If blown, you will need to find cause of short as sliding the radio back in it's slot shouldn't blow the fuse.
The only bracket would be the cage that came with the stereo. There isn't a bracket per say for that year Civic.
You wouldn't happen to know which fuse it is? My box doesn't have the diagram on the lid.
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
chgofirefighter
Apr 18, 2015 08:08 PM
