97 civic fog lights not working
Old Jan 30, 2014
BradyEJ6's Avatar
BradyEJ6 is an unknown quantity at this point
hello guys i just installed my civic ebay fog lights today perfectly, the switch even lights up orange like its supossed to, fuse is good, relay should be too, but the lights just dont light up, has anybody experienced this before? i tried searching but couldnt come up on much, thank you for your time.
Old Jan 30, 2014
GolNat's Avatar
Prelude Owner
Re: 97 civic fog lights not working
Originally Posted by BradyEJ6
relay should be too
Can you feel it switch when you press the fog light button? Do you have a volt meter?
Old Jan 30, 2014
BradyEJ6's Avatar
no i dont have a volt meter and yes i can feel it clicking
Old Jan 30, 2014
GolNat's Avatar
Prelude Owner
Ok, so your probably getting power to your relay if it is clicking (best to check with a meter). Is the fuse from the relay to the fog lights ok?
You need to check if your getting power to the lights and work back to the switch. A test light would work. A wet tongue would also.
Old Feb 4, 2014
BradyEJ6's Avatar
okay so the company sent me new wiring, plugged it all up, new relay and switch, nothing, light on switch comes on, but still nothing, whats wrong?
Old Feb 4, 2014
GolNat's Avatar
Prelude Owner
whats wrong?
Installation error. Or both your fog light bulbs are bad (probably not).
Did you get a meter? Do you have pics? Can you explain how you wired it?
Old Feb 13, 2014
Couran's Avatar
Couran is an unknown quantity at this point
Complete cooling system service. Drain, flush, new thermostat, clean exterior of radiator, install 50/50 mix of coolant, bleed air from system, check operation of water pump and cooling fan.
CarStuff
Dec 6, 2020 12:52 PM
Linda0818
Apr 23, 2015 11:30 AM
smmahan
Apr 15, 2015 08:17 PM
dooner24
Apr 14, 2015 07:51 PM
AlpineCivic
111
Oct 20, 2003 07:31 PM
