2011 EX COUPE STOCK OEM Wheels and Tires MINT UNDER 500 miles
I HAVE A NEARLY BRAND NEW SET OF BEAUTIFUL 16" OEM WHEELS ,CENTER CAPS AND BRIDGESTONE TURANZA EL400 TIRES 205/55/16 OFF OF A 2011 HONDA CIVIC EX COUPE ..THEY WILL COME AS PICTURED MINUS THE TPMS SENSORS THEY WILL BE REMOVED BEFORE PICK UP. THAY ARE IN PERFECT CONDITION WITH LESS THAN 500 MILES ON THEM YOU WILL NOT BE DISSAPOINTED . PICK UP ONLY I WILL NOT SHIP THIS BEAUTIFUL SET .. ALSO CASH ON PICK UP IS THE ONLY FORM OF PAYMENT PLEASE !! LOCATED IN FAIR LAWN NJ.. 201 522 5863 IF WANT TO CALL.. THANK YOU ..
Rim Material: Alloy
Aspect Ratio: 55
Rim Width: 6.5
Rim Diameter: 16
Number of Bolts: 5
Load Index: 89
Bolt Pattern: 5x114.3
Speed Index: H
Hub Bore: 64.1
Tire Brand: Bridgestone
Rim Brand: HONDA OEM
Car Type: Passenger/Performance
Rim Structure: One Piece
Tire Type: All Season
Section Width: 205
Rim Material: Alloy
Aspect Ratio: 55
Rim Width: 6.5
Rim Diameter: 16
Number of Bolts: 5
Load Index: 89
Speed Index: H
Hub Bore: 64.1
Section Width: 205
mattdoc
Mar 14, 2017 12:10 PM
C6GrandSport
Apr 25, 2015 09:41 PM
eXNBP
Nov 21, 2001 10:34 AM
