1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Help..Clutch??
Old Oct 7, 2013
hoiguibbo's Avatar
hoiguibbo is an unknown quantity at this point
Help..Clutch??
Hi all, I'm new here, name is guibbo. I love Hondas ever since I was little. Dad had a Honda City and couzins have civics back in p.i. I'm now 21 and bought an ej1 on my 21st from my uncle which i suppose he had well taken care of except broken ac.
I ran into trouble with my car's clutch last tuesday after i test drove it with it's new tires and had oil changed. I was feeling confident till i kinda speeded through first and 2nd gear up until 3rd, i got in gear but I heard a click/minor pop. Pulled over to the side of the street. Turned my car on and it turned on just fine, except it wont get into gear. Also when i turned it on and stepped on the clutch, there is still pressure but the pedal isnt full motion anymore just goes half way up and abit stiff. It would go into gear if it was off but it's not making as smooth. So i tried shifting to first while it's off then turn it on and run it. It would make a whirring noise or some weird noise. Engine is fine, also transmission is okay. Suspecting clutch disc broke, what do you guys think is wrong with it? i really need your help cuz its my dd and I can only afford so much. anyone from bellflower or cerritos Ca. area that recommends an honest mechanic? thank you guys. i'd appreciate any advice/tips.
Old Oct 16, 2013
kellogg6316's Avatar
kellogg6316 is an unknown quantity at this point
Re: Help..Clutch??
if the disk broke you would be able to go in and out of gears and nothing would happen. what ever it is , you have to drop the transmission and take a look.
