Tein Springs? SKA22 AUB00 TEIN s Tech
I am getting some conflicting specs from different sites about these springs. Some say the only work on 01-05 coupes and others say they will work for all models. Has anyone used these on a 4dr? I have an 03 civic hybrid. It has the same struts as an 02 coupe. Any info would be helpful. Thanks
Re: Tein Springs? SKA22 AUB00 TEIN s Tech
as far as suspension spring fitment, they are all the same for 01-05.
however, the better companies will make different sets for the coupe and sedan. the difference is mostly found in the rear spring in order to compensate for the extra rear weight of the sedan.
Yea, I have read that if you have coupe springs in a sedan then the back will sag and if you have sedan springs in a coupe then the back will be higher.
My Eibach's made my sedan sit lower in the back, I'm thinking that's why.
2002ExCivic
22
Sep 28, 2015 08:29 AM
TheRiddicles
Sep 21, 2015 01:28 AM
