Raceland Coilover Opinions??
Re: Raceland Coilover Opinions??
i have googled them but all the replies seem to be from people who haven't actually tried them. my gut feeling is that they arn't that good but i want to get people who actually have them like dnice78.
I also do not want to spend alot of money because i will be changing car's within 2 years. I just want my civic to handle much better, i'm not that interested in slamming it to the ground.
My friend had them on his EM2. Lasted about 1 year and the right-front strut failed at the hub connection. Damaged his steering components and crushed his fender. Even after that incident, he just order a new replacement coil and other parts and he's still riding on racelands 2 years later
upgrade your sway bars,lowering springs like Neuspeed,Eibach,Tein S Tech,Ground Control,Progress Technology or better tires. tires make all the difference in the world.
http://www.corsportusa.com/store/cat...a&filter_id=19
http://www.corsportusa.com/store/cat...&filter_id=264
http://www.corsportusa.com/store/cat...a&filter_id=12
http://www.corsportusa.com/store/cat...&filter_id=259
http://www.corsportusa.com/store/cat...a&filter_id=28
will lowering springs help with handling or are they mainly for lowering the car. that was why i was interested in coilovers because i thought lowering springs just lowered the car while coilovers actually improve handling? Thanks for the replies
The best handling upgrades you can do right away:
Bigger rear sway bar & street performance tires.
Those make the biggest difference. Suspension components help too, but that depends on the stiffness of the coils, and from what I've heard, racelands are not very stiff.
If you want a good lowering setup that's cheap, go with lowering springs (Neuspeed, Eibach, or TEIN) and combine them with Tokico HP Blue shocks.
It should be around $400 for that combo and much safer and smarter than overly-cheap coilovers.
Or you might do what I did and realize that installing coilovers is easier and save about $900 to do it well. I never expected to lower my car, but things change quickly when you fall in love with your car
I already got the street tires, will be ordering rear sway bar and lowering springs. is there any other companies other than Tokico with the HP Blue shocks that i should look into?
The new setup is Tokico Blues with Neuspeed sports.. Im spending a bit more to replace the strut mounts on the front and back and adding some wheel spacers. Total is coming to about $700.
Tokicos - Fronts $240 (2) , Rears $160 on Amazon ($400)
Neuspeed Springs $170
Total for standard parts are about $570
I spent another 150 on replacement parts as the strut mounts are original, rusted and beat.
Could have got some coils for the same price but all depends what you want.
looking at those prices it may be a better option to go with coils depending on the condition of whats already there. Which is easier in terms of labour, the springs/shocks, or the coilovers?
Even so, with coilovers, you don't need to use a spring compressor as the lock nuts provide the compression when you adjust them. Spring compressors are a hasle in my opinion and was one of the reasons I decid to go with coilovers in the end.
Not sure why everyone says spring compressors are hard.... Can rent them for FREE from your local pepboys and / or auto zone.... pay 50$ get it back when you return it.
Super easy to use...
Remember some coils require you to use stock tophats and strut mounts... unless you buy all new parts to that you will have to dismantle the stock strut anyway requiring the use of a compressor....
Stock struts are not compressed too tightly to teh point where you'd need a compressor to take them apart. As long as you safely use the foot technique demonstrated in Mex's suspension tutorial in a wide open area (and cover parts with a towel to help keep parts from flying), disassembly is really easy.
The good coilovers don't start until you hit almost the $800 range. For that money, you've got SkunkII, Megan, and TEIN coilovers. All are pretty good (I have TEIN Basis myself)
I'm sure there's plenty of dealers in Canada.
(Lucky you, this forum is dominated by Canadians, excluding me)
There are some great coilovers in that price range, so start looking and let us know which ones catch your eye.
nothin' to do with racelands...but after lowering mine on teins, i realized i want to go lower. i dont know if i browsed enough but for around the same price of gc+koni's, i might juss get hsd coilovers off tdotperformance.com for 1280..free shipping..no duty, custom, brokerage ****.
