Civic 98 Squealing sound
Old Mar 25, 2013
x3nzox's Avatar
x3nzox is an unknown quantity at this point
98 civic ex
198,9xx Miles
Ok I recently replaced my o2 sensor, Cel light still on, throwing code p0138 now, before it was p0171.
I recently drove 900 miles and a squealing on my drivers side started. It comes and goes, and is noticeable at low speeds, but can't really hear it at high speeds( maybe engine too loud)
In addition to that, when I drive at 70-80Mph my steering wheel especially and car shakes. I'm not too sure if they are part of the same problem.
Maybe its time to dump this car.... I was hoping for 200,000
Any thoughts
Old Mar 25, 2013
Re: Civic 98 Squealing sound
P0171 definition is "Fuel metering lean". Not normally caused by the O2 sensor, but could be.
Which sensor did you replace?
What did you replace it with?
P0138 definition is "High voltage problem in the secondary O2 sensor". That's the rear sensor.
EDIT: Could be caused by fuel system metering stuck rich, and could be related to the P0171
Squealing form where? Stick your head out the window like a dog and listen for where it comes from.
Squealing, only while moving? .....Does it change when you step on the brakes? Changes as you steer?
Front pads worn out. Wear indicator (squealer) noise.
Shakes @ 70+, usually tire balance. The faster you go, the worse it gets.
But if the shake goes away when you let off the gas at that speed it might be axles (inner joints worn).
(If the steering wheel twitches at low speeds or your seat waddles side to side at low speeds, you probably have a bad tire.)
Old Mar 26, 2013
x3nzox's Avatar
I replaced the o2 sensor in the front of engine.
Squealing is the belt on the right side of the engine when looking at the engine from the front of the car. squeals on and off regardless of what i do
accelerate, brake ,idling
Shakes only at 70+, I drove it at 65 today and there waS nothing
It does not shake when I brake so it cant be warped rotors
No waddling at low speeds, only when I go 70+
Old Mar 26, 2013
(You didn't answer the other question.)
So, the new code is dealing with the rear sensor now.
I have no way of telling if it is related to your new front sensor.
It could be, but there isn't enough info for me to make a judgement.
You should have said that in the first place. Makes things a lot simpler if you reveal all that you know in the original post.
Horribly loud squalling is usually because (one of)the belt(s) is too loose (your car should have 3 belts).
Inspect, then adjust it tighter or replace it.
I'd GUESS it will be the alternator belt.
If it isn't a loose belt, more inspection needs done. Harmonic balancer coming apart? *shrug*
First step: Get the tires balanced.
HTH
Old Apr 5, 2013
x3nzox's Avatar
I replaced it with a bosch o2 sensor.
The squealing noise also has this burnt rubber smell so im assuming i have to change the whole belt
Old Apr 5, 2013
Inspect and evaluate. Then decide.
Yeah if it was a belt burning, it probably needs replaced.
Old Apr 11, 2013
x3nzox's Avatar
turns out it was compressor belt.
And I got the wheels balanced, but i cant really test it out in NYC, speed limits 55, gotta test it outside
Linda0818
Apr 23, 2015 11:30 AM
tattedlariat
Apr 12, 2015 07:55 PM
WhosYoDadday85
Bolt-on Engine Performance
Nov 6, 2001 08:06 AM
01civicboi
Nov 2, 2001 07:33 AM
artychris
Sep 3, 2001 03:39 PM
