1999 honda civic ex coupe stuck in theft mode?
Old Feb 6, 2013
ashley.renee's Avatar
ashley.renee is an unknown quantity at this point
The keyless entry button to my car got washed in the laundry last night so it is no longer working. I tried leaving it in rice and drying it out with a hairdryer. Whenever I unlock the door with my key and open it the alarm goes off. The only way to stop it is to unhook the battery or close the door and lock it back with the key. Because the car is in theft mode I cannot crank it or anything. Went by the honda dealership and they said it's probably stuck in theft mode so a new button will not help. I cannot drive it to them so I'd have to have it towed but I don't have the money to tow it. Does anyone know how to override the anti-theft system or what I can do to fix this?
Old Feb 6, 2013
Re: 1999 honda civic ex coupe stuck in theft mode?
USA (market) car or Canadian car?
Factory or aftermarket system?
Factory fob (typical)
Got the user manual for the security system? (I was looking for user manual info about the valet switch, but couldn't download the info right now.)
I'm gonna go out on a limb and say to TRY remove fuse #6 from the dash fusebox and see what happens with the alarm. (I have NO idea if this will do anything helpful.)
If no help, put the fuse back in.
Next I'd try disconnecting the security control unit. Just unplug the one large connector from the box. See if the car will start now.
Location and drawing are on page 6, step 18 of these instructions (best I could find on the net on short notice) http://www.handa-accessories.com/civ...ritylxexvp.pdf
EDIT: Note: I can only guess this should work, all I have to work with are wire diagrams and internet.
Then get a new fob that works?
Old Feb 6, 2013
Thank you! I am going to try to remove the fuse tomorrow since I don't want to wake the neighbors up. Haha. I will let you know if it all works!
Also, it is a USA car and it is all stock, no aftermarket.
Old Feb 6, 2013
Great.
Read through those instructions I linked so you know where to disconnect the security control unit--- if the fuse alone doesn't take care of it.
Civicman92296
Apr 23, 2015 09:22 PM
jessicakaybby
Apr 20, 2015 12:11 PM
aultman1990
Apr 19, 2015 07:14 AM
Killagi
Apr 12, 2015 10:42 AM
