Diagnose oil leak on 2001 LX
Old Dec 4, 2012
Rem7mmMag's Avatar
Rem7mmMag is an unknown quantity at this point
I have recently been having over heating problems and I'm not sure if it is related or not. However I have an slight oil leak and I'm not sure what the seal is that is leaking. I know where (see picture attachments) but I don't know what. it is a very slight leak not enough to even make it to the ground but it is slowly getting all over the transaxsle. If someone could tell me what this is and what seal it is that would be great!
ID:	84383   Click image for larger version
Old Dec 5, 2012
mikey1's Avatar
Re: Diagnose oil leak on 2001 LX
either the valve cover gasket or the end cap,
remove the valve cover and replace both,
you need to use silicone at the corners of the valve cover gasket as the manual says
Old Dec 7, 2012
Rem7mmMag's Avatar
"either the valve cover gasket or the end cap,"
Its definitely not the valve cover gasket did you even look at the picture? It is where the arrows are pointing.
Old Dec 8, 2012
mikey1's Avatar
the only other thing it can be is the end cap
Old Dec 8, 2012
Rem7mmMag's Avatar
I believe that it is coming from the camshaft seal if thats what you meant by end cap.
Old Dec 8, 2012
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
It's called the "cylinder head plug" if we're going get names correct here.
P/N 12513-P72-003
Old Dec 8, 2012
Rem7mmMag's Avatar
P/N 12513-P72-003
The manual refers to it as what I said. I honestly didn't know what he meant by end cap. I'm not trying to get into a pissing contest I just need help identifying the problem and fixing it.
Thanks for the part number.
Old Dec 8, 2012
Rem7mmMag's Avatar
and I found how to change it out
Old Dec 9, 2012
mikey1's Avatar
the big black round circular thingy at the end of the cam
is that a better description?
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
mattdoc
Mar 14, 2017 12:10 PM
LionSpratt
Jan 29, 2017 11:07 PM
RIPSAW
Nov 6, 2015 04:36 AM
davidpaustin
May 20, 2015 12:59 PM
