Car does not start, possible immobilizer problem
Old Jun 3, 2012
amol's Avatar
amol is an unknown quantity at this point
Hi,
Car model: LXI, iVTEC, 1.8L, 2008 model.
I was cleaning the car interiors and had kept the lights on, along with the radio, while the engine was switched off. My friend started the car, with all the lights on and reversed the car. After keeping the light on for an hour, the car does not start now.
The green key light (immobilizer) went on for a couple of times after the key was taken out from the key hole. The car makes a peculiar fast-knocking sound, but does not start. I tried with the valet key as well, no luck.
Have verified the battery output is still 12.2V, and the transponder key battery voltage is 3.0V. Hence, I can rule out any battery issue.
What should I do? Is this surely an immobilizer issue or is it a problem with something else (ignition coil, spark plug)? Kindly note that I have added an amp and a JBL subwoofer to the car.
Please help!
Thanks,
Amol
Old Jun 3, 2012
Re: Car does not start, possible immobilizer problem
The battery has been run down.
Jump start the car.
Report back.
CarStuff
Dec 6, 2020 12:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
dragonsblood
Apr 27, 2015 12:28 PM
McD
Apr 16, 2015 10:46 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
