2011 Honda Civic Transmission Fluid
I have a 2011 Honda Civic and the check engine light is on. I drove it and when I hit the gas, the engine revs up, but the car doesn't speed up. I tested it and it gave us the code PO843 and said, transmission fluid pressure sensor/ switch A circuit high. I do not know what this means. What could be causing this problem? Please help. Thank you.
Re: 2011 Honda Civic Transmission Fluid
2nd gear pressure switch is either bad, wires chewed by rodents, or the trans shot craps.
Go to a dealer. Warranty (unless it has rodent damage to the wiring).
jessicakaybby
Apr 20, 2015 12:11 PM
