Subaru-style powered headlights
Hey guys, first post here.
I used to drive a Subaru Impreza and one nice thing was that the headlights would shut off when the engine was shut off, even if the switch was still on.
I was thinking I could make my Civic do this by adding a relay like the following diagram:
http://imageshack.us/photo/my-images...eadlights.png/
It would basically depower the circuit when the cig. lighter isn't getting any power (car off or starting).
Anybody see a problem with this? Seems simple enough.
Kolea
Kolea
Re: Subaru-style powered headlights
just build a basic HID relay and put pin +86 from the relay to the ACC wire. but make sure you put an inline fuse and a on/off switch just in case u want to disable ur headlights on the fly.
you could also tap ur lowbeam +V into +86 so that if u turn off the connection from ur +ACC you can still control it with ur stock headlight toggle
no need for that complicated wiring diagram.
And the stock headlight toggle would still control the lights while the car is on (and the relay receiving power). But this way I could just leave them in the on position all the time and not have to worry about the battery running out while the car is off.
Anticrosswalk
Jul 21, 2015 01:37 PM
