1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1995 civic lx (need help)
Old Jul 5, 2011
lilbizzy92's Avatar
lilbizzy92 is an unknown quantity at this point
Exclamation 1995 civic lx (need help)
so i just got a 95' civic lx 4 doors... everything is stock... but its old!!! 125k miles ... can someone help me out ? i want to fix everything under the hood and make it run like new... what do i need
Old Jul 5, 2011
cooncatcher19's Avatar
cooncatcher19 is an unknown quantity at this point
Re: 1995 civic lx (need help)
you probably want to get the valves adjusted or retuned cause that probably hasn't been done just do a full tune up sparkplugs, wires, fluid change and all that good stuff. i have a 97 hx and i had the valves worked on cause it ran good but also it ran a little off and after that it ran like new so try that and see where it puts you
Old Jul 5, 2011
kwiks93's Avatar
Real McCoy Tattoo
kwiks93 is an unknown quantity at this point
Also want to check and possibly change the timing belt. Most people forget to do it and the next thing you know Bam bent valves. BTW it's not old lol mine has 260k miles on it and the motor has under a hundred, so you have a long while to go before it's old, lol.
Old Jul 18, 2011
Wrx25rs's Avatar
Wrx25rs is an unknown quantity at this point
125K engine still in mid age, not old! Don't forget to adjust the valve if you changeing timming belt!
beneditti
Jan 15, 2016 12:31 PM
locozoko
Apr 6, 2002 09:00 PM
Cilvic
Nov 15, 2001 04:54 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
