Planning to turbo the D17
Old Jun 20, 2011
SlimRisk's Avatar
Busy Speeding!!
SlimRisk is a jewel in the roughSlimRisk is a jewel in the roughSlimRisk is a jewel in the rough
I have a NA d17 right now with only I/H/E and I plan on running a turbo. Right now I am preparing for the d16y8 manifold swap and had a few questions and what not. Ive heard users say when you do the d16y8 swap the engine runs lean at idle because of increased air flow. can the engines oxygen sensors not compensate for this? and when you boost the d17 why do you have to run a piggyback or a standalone? wouldnt the map sensor inside the manifold (good for up to about 10.63 psi) sense "Hey, theres a lot more pressure in this b*tch, i should tell the ecu to dump more fuel in". isnt that what its for?
Old Jun 20, 2011
MindBomber's Avatar
Live for the Twisties
Re: Planning to turbo the D17
No, the 02 sensors can't compensate for it, it's to far outside normal conditions to adjust. If I weren't I'd already have done the swap.
Why do you need to run a piggy back or a standalone, I'm going to assume your asking why run the standalone. You should run the standalone for the increased abilities it gives you while tuning and running the engine, on a piggy back you only have partial control over your the ecu because it's fighting the adjustments you make.
Old Jun 20, 2011
SlimRisk's Avatar
Busy Speeding!!
I was just wondering why the map sensor and all the other air sensors cant detect the extra air in the intake manifold and tell the ecu to compensate for it and up the fuel pressure. isnt that what the map sensor was made to do?
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
ken4444
Sep 30, 2015 07:37 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
