Interior Red Light Not Flashing Anymore!
Old May 28, 2011
DH757's Avatar
DH757 is an unknown quantity at this point
Exclamation Interior Red Light Not Flashing Anymore!
I was checking out my cars rear lights today.
I happened to notice that the red light inside the car that is against the window does not want to turn on anymore! If I remember correctly it used to flicker 3 times and then stay on.
My EM2 has the rear spoiler as well and that's working.
What's the name of this rear light?
I looked inside the trunk to see if there was any bad wiring, but there's not even a connecter under the light bulb. I see 2 pins under the light itself. Is this disconnected?
Can I have the spoiler and the inside light turn on at the same time?
I push the Brake Pedal but it doesn't turn on anymore.
What's wrong?
Old May 28, 2011
Re: Interior Red Light Not Flashing Anymore!
usually that connector gets moved to the spoiler light when you install it. there is no reason to have them both come on. but if you must, i prolly have an extra connector that will fit the 7440 bulb socket in the pic. you would need to splice that connector into the wiring going to the spoiler light. you can safely run both because the spoiler uses lo power LED lights and the other deck light is a 7440 bulb (21w). so the leds do not add much extra draw to the total power maybe 1-2w.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
jc33312
May 12, 2015 03:17 PM
Linda0818
Apr 23, 2015 11:30 AM
supercivic01
South
Nov 30, 2001 11:27 AM
galaga3
Oct 1, 2001 01:56 AM
