questions about the mini me vtec swap
i got the swap in my 96 civic completely rebuilt, valves etc have been set, ecu has been programed works great just wondering what things i should expect or fix before it goes
Re: questions about the mini me vtec swap
if the engine is out make sure that you have a new timing belt, accessory belts and water pump in it. Keep in mind that the d16y7 bottom end in stock form is not that strong of a bottom end and usually does not hold up to high revs that well, so do not expect to be able to hammer on it all the time and have it last. The d16y8 bottom end is stronger than the d16y7. The compression will also be bumped up with this swap giving around 135 hp or so. Keep on top of maintenance and take it easy on it until the engine is broken in if you had a complete rebuild done.
thanks man u might be able to help me out a bit, the car is doin a little sputtering not sure whats causing it checked oil, intake for it getting air makin sure it aint starving it, wondering if it might be an injector, shoots out a back fire every once and a while starting to get a little frustrated, its idleing kinda ruff any ideas
well backfiring means you are not getting a complete fuel burn, run fuel injection cleaner through the fuel tank (I happen to like seafoam for this but there are other good brands) also check all 4 plugs and let me know what the tips look like, (black, brown, white etc.)
ill do that tonight, it seems to only run rough when its cold once it warms up it seems to get better, what it does is when i start it, it just stalls unless you give it gas rite off, but while your reving it its sputtering and as soon as u let off it will stall for the first few times.
thana
Jun 15, 2020 07:05 PM
dbagaus
Jun 10, 2015 09:29 AM
