DIY timing belt or have mechanic do it??
Old Jan 31, 2011
jeffconnell12's Avatar
jeffconnell12 is an unknown quantity at this point
Hey guys, my cars a little over 100k miles, and ive got some squealing come from one of my belts im going to see which one but regardless this made me notice my timing belt is up for a change, i like to learn new things but am by no means a mechanic, i have a fairly good stack of tools, jack, stands etc, and am wondering whether you recommend me follow one of the DIY's on the site or suck up about 400 bucks and bring it to a mechanic? thanks.
Old Feb 1, 2011
BobDobolina's Avatar
TRUST me! I'm Idiot Proof!
BobDobolina has a spectacular aura aboutBobDobolina has a spectacular aura aboutBobDobolina has a spectacular aura about
Re: DIY timing belt or have mechanic do it??
Do it man!! If your going to have some jack@ss monkeying around with your car, may as well be you, right?!
Just follow this excellent write up, and dont cut corners.
I did mine over the weekend, last week.
Good luck!!
Old Feb 1, 2011
BlueEM2's Avatar
Whachya lookin at?
Dooooo it... Make sure you buy the crank pulley holder tool or you will find yourself stuck! but its doable. It's actually an easy job if you take your time.
Old Feb 1, 2011
MindBomber's Avatar
Live for the Twisties
I've been thinking about whether to DIY my timing belt or take it to the dealership for awhile - I decided to take it to the dealership, because it takes a good 2 days to complete if you've never done it before.
I'd rather work an extra two days over the weekend to cover the cost and let the mechanic install my timing belt.
Old Feb 14, 2011
creaker2's Avatar
creaker2 will become famous soon enough
I'm the guy who wrote the DIY listed above. It will take 2 full days to do the job. I strongly recommend that you have a helper to remove and replace the crankshaft bolt. Removing the bolt is the most difficult part of the job and it's best to have a helper. The cost for this job in northern California is closer to $700. Just remember that the civic has an "interference fit engine" so you will damage the valves if you get it wrong.
Old Feb 14, 2011
mrchowmein's Avatar
mrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura about
wow 700. i went to a honda shop in california, quoted 400 with water pump. took them 3 hours to do it.
my recommendation for OP is if you have the time and help do it yourself.
Old Feb 14, 2011
maxtierney's Avatar
EM2ti
I did mine about 6 or 8 months ago. I consider myself a fairly decent mechanic. I've performed all of my own mods. From suspension, exhaust, engine work, valve jobs, port/polish, welding, even mounting my own tires, etc, etc. I've got a lift at my disposal, an air compressor and all the tools you can shake a stick at(I'm not rich, I have a Marine Corp DIY Garage nearby). I even have 2 or 3 ASE Certified mechanics to ask questions or assist if I need help. This still took me 2 solid days to do. I can probably do it in less than a day now that I know what's involved. Remember how long it took you to do your first brake job? It's a snap now, right? Multiply that by 20. That's a timing belt.
I still had to do my homework. Watched a few youtube videos on how to remove that nut, buying the special tool, getting all the materials, gaskets, hondabond, etc.
Yes, if I can do it, anyone can. BUT... If you have never done it before be prepared for one of the biggest pain in the A _ _ jobs you can ever do on a car. I've swapped an entire engine in less time than it took to do my first timing belt. Getting in cramped spaces, busting knuckles, loosening and removing things that make no sense whatsoever, etc. If this is your daily driver, you are also under the gun to get it working before Monday too.
It's a daunting task. So get ready to commit - ALL IN or go home. Or to the mechanic, in this case. Good luck.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
slynger
18
May 8, 2015 06:06 PM
dosmastr
May 5, 2015 12:19 PM
bsmiley
Apr 27, 2015 01:27 PM
CivicVoz
Apr 16, 2015 08:07 PM
