Sponsored by:
Sponsored by: CARiD
another koni question
Old Apr 24, 2002
lilbluecivic's Avatar
lilbluecivic is an unknown quantity at this point
first-off i did a search and i couldnt find what i needed.i just bought gc coil-overs,koni's, and an ingals camber kit.rob from tornactive told me that there was a kit that i had to buy because the koni's were to short ,but the kit is on back order.did anyone install the konis and coil-overs with out the kit?if anyone did what did you use?
Old Apr 24, 2002
Bartkat's Avatar
Never heard of that. What about the coilovers would make the Konis too short? Konils fit fine with stock or ProKits or Sportlines.
Old Apr 24, 2002
RobearRacing's Avatar
RobearRacing is an unknown quantity at this point
Not too short...
Their adapters let stop the rattle, cause KONI are smaller in diameter than the stock shock.
Rob
Old Apr 24, 2002
oh ok ,has anyone used anthing in place of this kit?
Old Apr 24, 2002
are these what are on back-order
Old Apr 24, 2002
TOOLOWCIVIC's Avatar
It should be fine without them.
Old Apr 24, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
you NEED them.....the koni perch is designed SPECIFICALLY for a stock (or similar aftermarket spring, like H&R sport, or eibach), but it WILL NOT WORK w/ GC w/o the adapter
peace
Old Apr 25, 2002
TEKNIQ's Avatar
TEKNIQ is an unknown quantity at this point
Do I need them for my Progress before I get them installed[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Apr 25, 2002
do you only need the rears?and rob are these on backorder to
Old Apr 25, 2002
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
You can get the necessary Ground Control/Koni adapters for the rear directly from Ground Control. I just ordered them. $25.00 shipped.
Terry
tuvok
Sep 25, 2015 03:13 PM
junkyardguy
Sep 2, 2015 06:07 PM
cukaracha
Aug 29, 2015 05:27 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
