2001 honda civic overheating when turn on heater any help would be appreciated
Can anyone help my car started overheating about a month ago. I thought i had fixed the problem but now if i turn on heather the car overheats in minutes. I replaced the radiator fan switch and the enginecoolant tempature sensor. didnt start with the thermastat because i know that usually turning on heater will cool down the engine. The tempature will go down as quickly as it goes up. The heater started to act funny as well sometimes it will blow hot air sometimes cold.
Re: 2001 honda civic overheating when turn on heater any help would be appreciated
what did you do when you thought you fixed the problem?
I replaced the engine coolant tempature sensor and the radiator fan switch. At first the fan was not working when it was supposed to. I know that usually when the thermastat is bad the heater will cool down the engine that is why i did not start with that. The car will cool off as fast as it heats up.
sometimes the air is hot sometimes cold
I'd start with replacing the radiator cap and bleeding the coolant system. There might be air in there causing it to overheat. Are you sure you installed the sensor right? Does the fan work now?
yep, I agree with Tom (tbohar).
I'd probably go as far as covering all bases while you're messing with the coolant system. Replace the radiator cap, flush the system, replace the thermostat, then fill/thoroughly bleed the coolant system. All those things are minimal costs, and, depending on how much you spend on the radiator cap, should run you less than $50 total.
LionSpratt
Jan 29, 2017 11:07 PM
jessicakaybby
Apr 20, 2015 12:11 PM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
