B16A2 Build..Please help! i have some questions
i have a stock jdm motor that is turbod. i was looking into getting motor work done... wiseco pistons-but idk what compression to get for a turboed car???, eagle rods, comp cams- idk what to get for turbod car???, valves, valvesprings,retainers, main and rod bearings-what kind are good?,main bolts, rod bolts, and seals-what all seals should i replace?? what kind? and if i am missins anything else please let me know cause i am new to this game and woul like to learn a little
Re: B16A2 Build..Please help! i have some questions
You probably just want forged pistons and rods if you arent running a ton of boost. Wiseco are top of the line. For a boosted setup you want low compression pistons (8.5-9.0). Eagle rods are also good. If you are going to turn up the boost a lot you will want a forged crankshaft as well. A lot of companies sell rotating assemblies that contain all of these things plus the bearings. I would get ARP head, rod and main bolts/studs. You don't really need to upgrade the valvetrain unless you are going to put a bigger cam in it. If you are going to rebuild it, then replace all of the seals.
Talk to the machine shop that is machining your block so that you order all of the right sizes. Or they may be able to get the stuff for cheap too.
I hope this helps
I hope this helps
thanks for the info but for valves i wasnt too sure on what to get cause i was looking into skunk 2 retainers and springs but the valves themselves idk and i found an eagle rotating kit for a good price it came with everything but idk
You can get stronger or larger valves, but I don't believe it is necissary. It will not hurt to make stuff stonger though.
The retainers and springs are for if you get a stage 2 or 3 camshaft.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
junkyardguy
Sep 2, 2015 06:07 PM
martinsmartin
Aug 15, 2015 07:34 PM
