2001 Civic with Dezod turbo part-out
Old Oct 4, 2010
mp01vic's Avatar
mp01vic is an unknown quantity at this point
Selling a turbo kit, engine and transmission for a 2001-2005 Honda Civic.
Includes:
Built block
Supertech block guard
Wiseco low compression pistons
Carillo rods
ACL race bearings
For the cylinder head, recommend using your existing cylinder head, and swapping out the cam and valve springs.
Crower turbo cam
Crower valve springs
ARP head studs
New water pump, new oil pump, new thermostat
440cc injectors
Fidanza lightweight flywheel
Fidanza 4.3 clutch kit, ceramic 6-puck clutch disc (5000kms on it)
Engine has 15000kms since rebuild, 30000 kms total
Dezod T3/T04 turbo
Dezod intercooler
All required intercooler piping
TiAL blow off valve and wastegate
TurboXS manual boost controller
Dezod custom exhaust manifold, shorty pipe and downpipe with wastegate dump tube
Please email me for more info. There are several more parts included, too many to list. This is a complete kit, good for 300hp on pump gas. Engine blew timing belt, so valves are most likely damaged, but you can use your existing head and swap in the cam and valvetrain from this one. Pistons are 75.5mm, recommend you use and upsized head gasket to fit. This turbo kit can support 500hp if you change your injector size and run a different engine management system. These parts retail for over $15k.
Engine $800
Transmission $500
Turbo Kit $1200
Also selling:
Returnless to return fuel system conversion (Walbro 255 lph fuel pump, Aeromotive fuel pressure regulator, all required lines and fittings, modified in-tank float) $800
Megan Racing coilover suspension with bushings and camber kit $1000
Triple gauge A-pillar gauge pod, boost gauge, oil pressure gauge, wideband air-fuel gauge, all Auto-Meter, A'pexi turbo timer, $600 for everything
Optima yellow top battery $150
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
mattdoc
Mar 14, 2017 12:10 PM
bambuski
Nov 12, 2001 10:35 PM
CapYoda
Nov 11, 2001 05:17 PM
liljoe
Nov 4, 2001 01:27 PM
HitlistCivic01
Oct 27, 2001 07:47 PM
