1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
timing issue 82 1300fe
Old Sep 27, 2010
cobraboy's Avatar
cobraboy is an unknown quantity at this point
new to the group and seriously needing some help. recently had an ignition module go bad in my 82 civic 1300fe. replaced that, and now the the car has severely decreased top speed. it never was a speed demon, but can't get past 65mph on a downhill, with no wind (5th gear won't clear 3000rpm). before the module went out, it was bucking and surging at higher speeds. i've reset the distributor at numerous positions, from 0 degrees to 15 degrees advance, but still no top end. is it possible that the timing belt has slipped a tooth? could the new module be inferior or defective? i've seen some of the posts on this forum, and figure y'all would be the ones with some insight.
thanx in advance
cobraboy
Old Sep 27, 2010
J-Master Flex's Avatar
J-Master Flex is an unknown quantity at this point
Re: timing issue 82 1300fe
Is the car bucking when you attempt to accelerate? It sounds like your car had the same problem my 98 Civic HX had. It would buck violently when attempting to accelerate. When I unplugged the o2 sensor, the car ran perfectly fine (minus the exhaust fumes). But the problem actually wound up being the ECU though, and they certainly don't come cheap.
Old Sep 27, 2010
cobraboy's Avatar
since i replaced the ignition module, it doesn't buck anymore.....just really sluggish in higher gears. when it did buck, it did it at higher speed cruising and would bog down on low speed acceleration.
Old Oct 4, 2010
cobraboy's Avatar
Re: timing issue 82 1300fe---Problem Solved
Turns out Timing belt slipped 2 teeth. Got everything reset, and it runs better than it did when I first got it. Thanx for those that gave an effort to help with this.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
intensity
May 12, 2015 10:43 PM
Supramk3
May 11, 2015 07:55 PM
crowtoo
May 11, 2015 06:50 PM
civic_gt
Apr 19, 2015 08:15 AM
