Help with 04 civic
Old Aug 13, 2010
cameron12's Avatar
cameron12 is an unknown quantity at this point
Unhappy Help with 04 civic
Hey everybody, I recently picked up a 04 civic ex w/ automatic trans, bone stock, and roughly 55k miles. My problem is this car is showing the codes P1457, P0497, and it has trouble starting after filling up (or putting just a gallon or two in the car) I always tighten the cap atleast 3 clicks and have cleared it once but it still came back. If anyone can help, it would be greatly appreciated. Please help or point me in the right direction. Thanks in advance.
Old Aug 13, 2010
02civicsi02's Avatar
Low and slow!
Re: Help with 04 civic
What do the codes say?
Old Aug 13, 2010
Low and slow!
Ok p1457 has something to do with your evap system, the code says there maybe a leakage so you need to get the service manual and figure out what to do to fix it. This is the reason why you have trouble starting your car when you get gas. The evap system is your fuel system basically. and the other code I am not sure bout that one but just reseting the codes isnt going to help any you have to fix it first.
Old Aug 13, 2010
cameron12's Avatar
EVAP Emission Control System Leak Detected and Low purge, I believe. I will check it soon to make sure. Yea I know that clearing the code will not fix it but i was trying to make sure it wasn't that I didn't tighten my gas cap enough.
Old Aug 13, 2010
Low and slow!
Ok get that checked out and do you know what the other code means.
Old Aug 13, 2010
cameron12's Avatar
EVAP System Low Purge Flow
Old Aug 13, 2010
Phantomd's Avatar
Phantomd is an unknown quantity at this point
replace your gascap, otherwise you have a evap line that is leaking.
-Zach
Old Aug 15, 2010
cameron12's Avatar
ok well just replaced the cap and cleared the codes, so I guess we will see soon.
Old Oct 18, 2011
brewcrewearl's Avatar
brewcrewearl is an unknown quantity at this point
Did replacing your gas cap fix your codes? I only ask because I am having similar issues.
Old Oct 19, 2011
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
I had the same issue and gas cap did not fix it.
I started to fill up the car every time I needed gas (or it was cheap) and that seems to have helped a great deal but I still get the code from time to time.
I was bad about running the car on a 1/2 tank or less.
jonavin
73
Oct 4, 2004 07:18 PM
locozoko
Apr 6, 2002 09:00 PM
silvervtec01
Nov 4, 2001 06:56 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
