rim/tire size
Old Aug 9, 2010
Soldierboy87's Avatar
Soldierboy87 is an unknown quantity at this point
rim/tire size
I got some 17 inch rims for my civic. What tire size should I get. I don't wanna go too low on the profile but I know stock profile would look bad on rims that big.
Old Aug 11, 2010
sic1civic's Avatar
sic1civic is an unknown quantity at this point
Re: rim/tire size
when I had 17s, I had 205/40 R17s on it
Old Aug 11, 2010
Re: rim/tire size
I'd go with a tire size that messes with your speedometer the least. On my 2002 Civic ex with stock 185/65-15s, the tire size that messed with my speedometer the least was 215/45-17. I'd much rather have a correct speedometer, as well as a comfier ride than go with a tire with the smallest sidewall possible for that "low-pro" look, which will inadvertently give you a shittier ride due to the smaller sidewall, and make your car's speedometer and, by association, odometer reflect incorrect numbers.
use this to help you make your decision.
http://miata.net/garage/tirecalc.html
Old Aug 11, 2010
Re: rim/tire size
I actually don't really care too much for the low pro look. I just don't wanna go with too much or too little sidewall. I know I'll probably have to go with a slimmer tire size to make up for the bigger rim size over stock so my speedometer stays accurate.
Old Aug 11, 2010
Re: rim/tire size
Hey Riceboy thanks for that calculator. It's perfect for my question. After playing around with tire sizes that size rim seems perfect for the profile tire I would need to match the stock diameter.
68camerors
Sep 24, 2015 06:18 PM
