VTEC ? & Motor oil
Old Jul 15, 2010
Civictim's Avatar
Civictim is an unknown quantity at this point
VTEC ? & Motor oil
I'm new to Civics. I'm trying to figure out if all civics are vtec's. I have a 00 EX, D16Y8, and when I look up parts online, at say, Autozone, it says I have a vtec engine. I do know the engine is a sohc. Also, I will be putting a lot of miles on this car on the hi-way, running 75-85 mph. At that speed it will be humming at about 3500 rpm...and I'd like to know if 10w40 would be too thick a motor oil for this car. The oil would be Mobil 1 Synthetic.
Old Jul 15, 2010
97 Civic coupe's Avatar
97 Civic coupe is an unknown quantity at this point
Re: VTEC ? & Motor oil
Only Ex civics in this generation have VTEC.
Old Jul 15, 2010
02civicsi02's Avatar
Low and slow!
You forgot about the SI.
And to the OP yes you have vtec, the d16y8 is a sohc vtec motor.
Old Jul 18, 2010
ScottDR's Avatar
ScottDR will become famous soon enough
10W-40 would be way too thick and would only kill your MPG. Go with a 5W-20 if your engine is healthy (Honda backed dated their recommendation of 5W-20 for the 6G civics a couple years ago now). If it burns a bit, go with 5W-30 Mobil 1.
Old Jul 18, 2010
i would stick with 5w30 for highway driving. the 20 falls apart too easily in the heat.
Old Jul 19, 2010
Low and slow!
5w-30 should work out the best. 5w-20 seems to burn alot more especially in hot weather. If you go with 5w-20 run it during cold weather ans switch when spring comes around.
RIPSAW
Nov 6, 2015 04:36 AM
amrhamed
Jun 1, 2015 08:08 AM
Supramk3
May 11, 2015 07:55 PM
Grey
16
Jan 27, 2002 11:34 PM
civiccowboy
Nov 19, 2001 03:44 PM
