1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Radiator fan issues
Old Jul 10, 2010
95EX's Avatar
95EX is an unknown quantity at this point
Radiator fan issues
For some reason my fan wont come on now. Here is what ive found so far:
- jumped the thermo switch on the T-stat and the fan turns on
- new T-stat
- fuses and relays are good
so why wont this fan turn on? I was thinking of maybe just wiring it up to a toggle switch under my dash to turn it on when i need to. Where would be the best place to tap into the wires and run a line to a switch? would it be OK to run a wire strait from the battery to the fan?
Old Jul 10, 2010
Re: Radiator fan issues
maybe fan sensor went bad? try changing it first (this sensor is different from the engine temp sensor). but both are located near the thermostat in the cooling passage.
Old Jul 10, 2010
95EX's Avatar
where exactly would it be? Only one i see is the one that plugs into the t-stat housing.
Old Jul 10, 2010
i was not able to find a pic, but try to trace the wiring back from the fan motor. it should lead to the sensor.
Old Jul 11, 2010
95EX's Avatar
how can i test it forst before replacing it?
Old Jul 11, 2010
im not exactly sure on the test procedure for the older civics, but i imagine you should be able to put the sensor end in some heated water and see if the resistance changes using a multimeter to measure ohms. i think most sensors trigger around 200 degrees F. but if the fan works when you jump it, then most likely the sensor is bad.
Old Jul 11, 2010
95EX's Avatar
Ok so how about an easy fix.....
I was thinking of running a wore from the battery to a 15AMP fuse and then to a toggle switch then to the fan. That way i can just turn it on whenever i need it. I have these things and dont need to to buy anything that way.
what you think?
Old Jul 11, 2010
you can do that but first make sure the switch can handle that much power (the fan can pull alot of amps and easily kill most switches they sell at the store). usually for hi amp draw devices, a relay harness is used. dont forget a fuse on the power wire within 12 inches of the battery.
Old Jul 12, 2010
95EX's Avatar
hmmm...didnt think it would draw that much power. Anybody that has done this before have a setup they used and can share?
Bruce.Ringler
Jun 18, 2015 08:12 AM
zaboomafoozarg
May 30, 2015 09:21 AM
Lunar
May 22, 2015 07:43 AM
hokiedad4
May 3, 2015 10:06 PM
prowl
Apr 18, 2015 07:50 PM
