SoCal Dyno Day - Saturday, May 29 - 10a to 5p!
Hey guys,
I've arranged a dyno day with Harry @ HK, and I thought it would be nice to see a variety of cars so I've opened it up to a few different auto forums. Please read this thread in full for all of the information!
WHAT: SoCal Joint-Forum Dyno Day
I will be opening up this event to several automotive forums as space allows, and it would be great to see a variety of cars! You are more than welcome to invite people, but they MUST follow the instructions to register or they will not be able to run their car on the dyno for sake of time!
WHERE: HK Motorsports Dyno Shop
HK Motorsports Dyno Shop is located at 15020 Oxnard Street Unit A, Van Nuys, CA, 91411. Elevation: 773 ft. above sea level. For more info, visit www.hkmotorsportsdynoshop.com.
WHEN: Saturday, May 29
Important!!! FWD and RWD cars are being run in *separate sessions*! The first group will be FWD cars, from appx 10am to 1:30pm. The second group will be RWD cars, from appx 1:30pm to 5pm.
HOW MUCH IS IT, AND WHAT DO I GET?
Harry uses the tried and true Dynojet 248X. You will get 3 pulls on the Dynojet, to include HP, TQ, and AFR's. Small adjustments in between pulls are OK (such as boost controller or fuel trim adjustments), but please limit them to 5 minutes or less. The car cannot be lowered down from the dyno or disconnected to make these adjustments. The cost is $55, but we must have 5 cars registered. Your dyno sheets can show your results in several different combinations, and can be emailed to you immediately after your runs.
HOW DO I SIGN UP?:
To reserve your spot on the list, you must send a deposit via PayPal in the amount of $5 to: turbobrickindustries@gmail.com. Please send the deposit in "Gift" form, and make sure to include your name, year/make/model of vehicle, message board you represent, and whether your car is FWD or RWD (again, FWD cars will run from appx 10-1:30p, and RWD cars from appx 1:30-5p). The remainder ($50) must be paid IN CASH the day of the event. Please bring exact change!
THE LIST:
FWD: 10am-1:30pm
1) L8 APEKS, Volvospeed: '94 Volvo 855 Turbo
2) washedup, Volvospeed: '98 S70 T5
3) rsterns, Volvospeed: '98 V70 T5
4)
5)
6)
7)
8)
RWD: 1:30pm-5pm
1) L8 APEKS, Turbobricks: '75 Volvo 244GL
2) 760brick90, Turbobricks: '90 Volvo 765 Turbo
3) bawareca, Bimmerforums: '87 BMW 325is
4)
5)
6)
7)
8)
Any questions, please let me know!
DynoJet Model Number 248X
Measures up to 2000 + HP and 200MPH
Ignition Wire Inductive Tachometer Pickup Leads
Wide Band Air/Fuel Ratio System
Air Actuated Brake System
Remote Software and Brake Control From Driver's Seat
Automatic Conditions Measurement (absolute pressure, air temp, etc.)
Minimum Axle Width 29.5"
Maximum Axle Width 96"
Maximum Axle Weight 3000 lbs
Drum Speed Accuracy +/-1/100th MPH
RPM Accuracy +/-1/10th RPM
THE LIST:
FWD: 10am-1:30pm
4)
5)
6)
7)
8)
RWD: 1:30pm-5pm
4)
5)
6)
7)
8)
Touge
Ottawa
May 23, 2015 05:39 AM
Touge
Touge
May 20, 2015 10:54 PM
Touge
Ottawa
May 20, 2015 10:53 PM
