8th Gen 2006 - 2011.
Replace tail light lens cover
Old Jan 25, 2010
Teasip's Avatar
Teasip is an unknown quantity at this point
I've got a small crack in the side of my passenger side tail light lens. Is this easily accessed/replaceable through trunk access by pulling back on the trunk fabric cover? Estimate as to time needed from those who have replaced theirs? 08 Si sedan is the vehicle type. Thanks!
Old Jan 25, 2010
Teasip's Avatar
Re: Replace tail light lens cover
Unfortunately it looks like I can answer my own question. I found a DIY at a sister site and you have to loosen/remove bumper to access lower bolt holding in assembly. Best accessed with bumper cover removed/pulled away. Darn!
Old Jan 25, 2010
yeah sedans unfortunately the bumper should come off. you can try and reach behind the bumper and see if its possible for you to undo the single bolt of the taillight. sometimes you can with small arms and tools.
Old Feb 16, 2010
Teasip's Avatar
Replaced it this past Sunday with the assistance of my brother. Removed right rear tire, mud flap, and then associated screws. Bumper cover is flexible enough to pull away from corner without having to remove the left side. Used multiple rachet extensions to reach the problem screw on the bottom of the housing. Only hiccup was that apparently a bulb was burnt out so I had to go get one. Other than that, easy.
Old Mar 26, 2010
emgilg01's Avatar
emgilg01 is an unknown quantity at this point
Can I ask you where you found the tail light lens cover? I need one as well and all I can find are complete assemblies! Thanks.
Old Mar 26, 2010
they are only sold as complete units. the cover is welded to the rear housing.
Old Mar 28, 2010
Teasip's Avatar
Ordered it from an online dealer out-of-state.
Poopies
Apr 20, 2017 11:36 PM
Erndog81
Oct 31, 2015 03:01 PM
shaejb15
Apr 12, 2015 11:38 AM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
