Center console bulb replace DIY and others
Did a few searches, maybe answers are here. If so sorry same question/s being asked.
98 LX automatic with burned out center console bulb. Any DIY for replacement?
Also heater / AC control panel bulb/s out.
Doesn't look obvious to me as to how to replace these bulbs.
TIA --
Dave...
TIA --
Dave...
Re: Center console bulb replace DIY and others
TIA --
Dave...
TIA --
Dave...
I have the same problem with the ac/heater bulb not sure about that one, or if it is even replaceable.
I have done the center console, you remove the rear portion first a few screws lift off, then remove the front section a few screws where the shift handle is that pulls off. Right under the indicator P R D etc there is a little wire with a bulb holder just pops out, tiny little bulb, might have to get it at the Honda dealer.
I have a coupe, but I believe the consoles are the same. Push the 2 front seat up and look at the sides the arm rest console you will see them. the front section has 2 screws towards the back 2 towards the front. Then lift the pieces off.
thesushiboy
Apr 12, 2015 02:54 AM
2k2civic
Dec 2, 2001 11:35 PM
