Sponsored by:
Sponsored by: CARiD
tenzo racing seats in my 2k1 coupe
Old Apr 16, 2002
blowhole's Avatar
blowhole is an unknown quantity at this point
im putting in 2 tenzo r rally seats either tomorrow or the next day....red seats i think they looi hot in my car ...well ill have pics up in a day or 2....lemme hear what you think
Old Apr 16, 2002
RedDragon333's Avatar
Those are the ones i wanted but watch out for your SRS light itll go off....the 2k1s have and SRS system that when the airback comes out from the wheel your seat belt sonnectors retract to tighten the seat belt on you and when you remove the seat unless the seats your putting in there have a SRS system like this itll go off...but i believe there is a trick to fix it in the DIY but itll look tight in there those are the ones im gonna get if i cant fit the EK9 seats in there
Old Apr 18, 2002
tRu's Avatar
tRu
tRu is an unknown quantity at this point
does tenzo-r have brakets? for the 2001 civic?
Old Apr 26, 2002
blowhole's Avatar
no.. tenzo dont got the brackets for an 01 civic....so they gave me the brackets for a 96-00 civic and i had to modify them and weld to make em fit.....but they should have the brackets out within the month
Old Apr 26, 2002
SQCivic's Avatar
SQCivic is an unknown quantity at this point
RedDragon333 - Do you know for sure that if you add aftermarket seats and install the seat belt attachment with the SRS sensor from the old seat to the new, your SRS still will not function properly? I've had a hard time finding an answer. Thanks
Old Apr 26, 2002
RobearRacing's Avatar
RobearRacing is an unknown quantity at this point
TENZO seats are actually really nice..i love the ALL RED ones...ohhh so swweett...
Hope you got 2..i think it will look hot dude..
Post pics after.
Rob
Old Apr 27, 2002
VTEC2001CIVIC's Avatar
VTEC2001CIVIC is an unknown quantity at this point
I've got the Tenzo Rally 2's in black- sweet set of seats- SRS light will not go off as long as u connect everything back the way it was (attaching seat belt wires)and Sparco seat brackets fit Tenzo seats. Sparco makes brackets for the 2k1 (i know because i have them). The 92-00 seat brackets don't have a small hole drilled for the flange on the
seatbelt(gas filled tube)so u'll probly have to drill a whole for those. Other than that and all the mig welds, should'nt be too hard to make. goodluck. Also, i didn't turn my ignition on when i had the seatbelts disconnected so that might be a good idea too.
~Jon
Nalmonte
Jul 22, 2015 09:08 AM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
elektrø
Jul 10, 2015 02:32 PM
ballmich
Jul 9, 2015 11:59 AM
