1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
vacuum gauge on 95 civic
Old Dec 3, 2009
koisser6284's Avatar
koisser6284 is an unknown quantity at this point
hey , i recently bought a 95 civic dx coupe with a d15b7 and the previous owner install a vacuum gauge but didn't plug the rubber hose with t-fitting , i know there's several vacuum hose but witch one is the best for this application, does anyone know where to plug the t-fitting or have a picture that could help me ???
Old Dec 4, 2009
YSIDRAG's Avatar
YSIDRAG is an unknown quantity at this point
Re: vacuum gauge on 95 civic
Any port off of the intake manifold will do fine. But why do you and why would you need this? Is it a boost gauge or just a vacum gauge?
Jay
Fabricated Performance
Old Dec 13, 2009
it's just a ebay (x tune) vacuum gauge , i have no idea why the previous owner put that there but i just want to get it working , i try every hose and the only one working is the one from the manifold to the fuel pressure regulator , but the needle barely move , is that normal ???
Old Dec 13, 2009
its possible the gauge is broken, also it will not move much unless you are driving.
Old Dec 13, 2009
when i drive it only move from 8 to 0 and other civic move from 25 to 0 ??? something wrong ??? ok go on youtube and write ''2000 Honda Civic Si hitting VTEC (a wild man driving!!)'' and watch is vacuum gauge working , is mine supposed to work like that ???
Old Dec 13, 2009
usually vacuum gauges are found on turbo cars, because the vacuum goes both ways (positive and negative) depending on if the car is in boost or not. i dont see why you would need it on a stock car. it wont tell you anything useful other than the engine is making vacuum, which it does 100% of the time.
Old Dec 15, 2009
i want to remove that rpm , shift light and vacuum gauge for the JDM look , mine is a DX so basic cluster , SI cluster are pretty nice but how hard they are to installed ??? are they use the same connector or i have to use de SI wiring harness ???
Old Dec 15, 2009
usually the cluster from the same year as your car should plug right in. im not sure about the si, but the ex cluster would work, and that has a tach too im sure.
Old Dec 15, 2009
EX and SI is the same , because in canada the SI is the sohc vtec. so the 92-95 cluster with RPM sould plug right in ?
bsmiley
Apr 27, 2015 01:27 PM
tylerginevan
Apr 27, 2015 12:29 PM
Braun
Apr 23, 2015 09:03 PM
blacklud
Apr 13, 2015 06:15 PM
fordfocussucks
Nov 6, 2001 03:16 PM
