17s on a 2001 Civic LX?
Old Nov 29, 2009
pwnderpants's Avatar
pwnderpants is an unknown quantity at this point
I just recently acquired a 2001 Civic LX 4dr and I want to get 17" wheels. Can anyone recommend any wheel brands that would fit as well as tire sizes that won't cause rubbing or get in the way of my brakes. My car has stock suspension and I don't plan on dropping. Also, does anyone have experience on how the ride is on 17s? If 16s are a better ride/fit I'm open to suggestions, thank you.
Old Nov 30, 2009
BlueEM2's Avatar
Whachya lookin at?
Re: 17s on a 2001 Civic LX?
The ride on 17's is crap. It's real bad for your suspension. It will make your D17 engine work overtime. This topic has been covered extensively, do a little searching. It's up to you but I would not go much bigger than 16's on a civic. Just make sure the wheels are as light as possible. Also, your going to get some wheel gap when you put rims on so you should probably lower the car as well. Just so it does not look silly.
Old Nov 30, 2009
kc8ktq's Avatar
kc8ktq can only hope to improve
If you want to stick with 17's, and still want ride quality, I would go with 215/45/17 on Enkei Racing RPF1's (wheels are only 15 lbs each). Wheel gap would actually decrease 0.4 inches with that tire size, and the speedometer reading is still within acceptable specs.
Old Dec 30, 2009
svtec's Avatar
svtec is an unknown quantity at this point
i had 18's on mine and the ride was not bad but then again we have pretty alright roads.
Old Dec 30, 2009
YSIDRAG's Avatar
YSIDRAG is an unknown quantity at this point
<----Has 20's and it rides fine.
Old Dec 30, 2009
2005civiclx's Avatar
2005civiclx is a jewel in the rough2005civiclx is a jewel in the rough2005civiclx is a jewel in the rough
get 17s the ride is fine. i have 17s and its not that bad just avoid potholes which you probably already do anyways so nothing will change. the only thing bad is yes you feel bumps more but you get used to it and its not that bumpy to me and my roads arent that great. i have 205/40/17 and i think it rides good. you could go bigger than 17s if you felt like it. its your choice. if you feel like 17s dont listen to people saying the ride is crappy cause its really not that bad. look on craigslist for rims first sometimes you can find a good deal on some rims.
Old Jan 19, 2010
electric130's Avatar
I have 215/45/17 tires on mine and the ride isn't much different than stock. the engine doesn't work overtime. acceleration feels the same as my stock 14" steelies. braking feels the same. cornering is hugely improved on the 215's. the only down side is the reduced wear life due to being an aggressive tire. typically low profile tires are softer compounds. i've got 30k miles on my current set, but they're done. i got 70kmi on my stock set.
Old Jan 19, 2010
Honda05's Avatar
Honda05 is just really niceHonda05 is just really niceHonda05 is just really niceHonda05 is just really nice
i agree with what hes saying.. ive had 17's for about 4 or 5 years now and ive never had any problems.. just get some good tires and you will be set
Old Jan 19, 2010
oney's Avatar
oney is an unknown quantity at this point
no problems yet and im running 205/40zr17 suspension wise im running the raceland ep3 coilovers and they feel great make sure you do it where you can align it immediately or you wont be able to drive anywhere it kicks the toe out of wack good luck with your car.
Old Jan 20, 2010
D940's Avatar
D940 should not be trusted
They aren't crap...I have 17's Chrome on a 2000 lx. It rides fine...Plus it will only ride like crap if you have crappy tires. Mine are low profile, 80w Admirals. They ride like any other car with low profile tires. If you want a smooth ride from any car with bigger rims and low profile tires you need a better suspension kit. The ONLY Downside to having bigger rims and low profile tires on a honda civic is that your gas mileage will drop about 4 miles/gallon.
Old Jan 20, 2010
D940's Avatar
Here is a look at my civic so you have an idea what it would look like...
Old Jan 20, 2010
i disagree with this. mine didn't change. i still get an average of 33mpg city/hwy combined. i got that on my stock 14's.
Old Jan 20, 2010
D940's Avatar
Do you have chrome wheels? bc Chrome ones are heavier...
Old Jan 20, 2010
yes i know chrome is heavier. what i was disagreeing with was your general statement that "bigger rims and low profile tires on a honda civic is that your gas mileage will drop about 4 miles/gallon." that is not and will not be everyone's results. will be dependent on the rim/tire combo. that's why i disagreed.
at any rate, for another visual, here's my 02 LX with 215/45/17's.
Old May 20, 2015
kyle27's Avatar
kyle27 is an unknown quantity at this point
I have a 2001 Honda Civic EX Sedan, and already have the 17's but havent gotten tires put on them yet. They are 215/45/17. Will I have any problems with the fitment, or will spacers be needed?
mattdoc
Mar 14, 2017 12:10 PM
bambuski
Nov 12, 2001 10:35 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
liljoe
Nov 4, 2001 01:27 PM
