engine overheating? smoke from manifold area
Recently the temperature guage has been saying that my engine is overheating when Ive only driven a few blocks. Then the guage will drop to normal (about halfway). Its kind of erratic.
I just replaced the radiator so it shouldn't be a broken radiator.
I also noticed that there is smoke coming from the area of the manifold when the engine is running.
I also go through engine oil really quickly.
Could these things be related?
Any ideas what the problem might be?
Thanks!
I have another post regarding the car not accelerating. Perhaps this problem is related to my other problems.
Thanks!
Re: engine overheating? smoke from manifold area
Yah, I think there must have been air in the radiator. No, I didn't bleed the air out and this morning I managed to pour about a 1/4 of a jug of coolant into it even though I "filled" it up when I put in the new one.
After adding the coolant it isn't overheating.
Thanks for your help.
There is a procedure on this website for how to properly bleed the air out of your cooling system. It involves the heat being on full blast and such. I highly suggest you follow it, so you don't have any more problems. It's easy to find if you search for it, and its a bit more involved, most people don't do it right until they read up on it.
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
thana
Jun 15, 2020 07:05 PM
blazebrown
18
Jun 2, 2019 12:31 PM
crowtoo
May 11, 2015 06:50 PM
