Ingalls Torque Damper d17 civic
Abortion Survivor
This is the Ingalls Torque damper for the d17 civic. It comes with all hardware to install and instructions. Good condition. 105 shipped pay pal to
Michalo_187@hotmail.com.
Abortion Survivor
Re: Ingalls Torque Damper d17 civic
from a website:
self-contained elastomeric shock that mounts on brackets between the engine and the chassis. It reduces extreme engine movement and dampens the motion, providing many benefits. The “Stiffy” was originally intended for the sport compact market, but can be used for some Hot Rod* applications if it is applied correctly.
Benefits:
Greatly improved off-the-line acceleration
Reduced wheel hop
Improved vehicle stability
Reduced shock loads on driveline components
Smoother shifting
Reduced wear on exhaust system joints
Less vibration transmission to the driver compared to polyurethane motor mounts.
Less shock load, compared to torque straps and chains.
Drifting
– helps reduce shock loads when wheels gain traction.
Reduce
s motor movement
– decreases the chance of motor parts rubbing against the hood and frame.
bump! I need this sold, I am broke!
Benefits:
Reduced wheel hop
Smoother shifting
Drifting
Reduce
s motor movement
from a website:
Benefits:
Reduced wheel hop
Smoother shifting
Drifting
Reduce
s motor movement
Benefits:
Reduced wheel hop
Smoother shifting
Drifting
Reduce
s motor movement
do you need to make any holes or mods to install this?
Abortion Survivor
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
