Remove Instrument Cluster
Old Oct 30, 2009
2k5reverb's Avatar
2k5reverb will become famous soon enough
Hey guys i have tried searching for this but cant find anything. How do you remove the instrument cluster on a 2005 civic coupe. I cannot get the trim peice off it is there a screw or something at the bottom? I could pull harder but it's cold out and i dont want to crack it.
Old Nov 1, 2009
2k5reverb's Avatar
Re: Remove Instrument Cluster
Sorry if i posted this is the wrong area but i am trying to change a burn out light bulb. Come with all the people that have changed their cluster lights to led no one will give a little advice on taking it apart.
Old Nov 2, 2009
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
what kinda trim is it? 2005 should be LED so it shouldent burn out. what bulb is burned out that your trying to fix?
Old Nov 2, 2009
there are two screws at the top of the bezel. then the steering wheel needs to drop to its lowest setting. the bezel will pull straight out towards you, but you need to wiggle your fingers in the back towards the bottom and really yank hard. its glued in and the first time will take the most pulling. once the glue weakens, it will be easier next time. but it will still go back in place cause there are two clips that snap in. after the bezel comes off, there are three screws holding the cluster in. take those out, then unplug green and blue connectors and the cluster should pull out.
Old Nov 2, 2009
2k5reverb's Avatar
Thanks gearbox.
fatih717171
Jul 25, 2016 06:22 PM
RSJ
Jul 23, 2015 11:29 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
ballmich
Jul 9, 2015 11:59 AM
fatih717171
Jul 8, 2015 12:14 AM
