1998 Civic D16Y Engine Oil Leak
Old Oct 26, 2009
civicwad's Avatar
civicwad is an unknown quantity at this point
I have a civic that has an oil leak from what appears to be the distributor shaft. I had the O-ring seal replaced on the shaft, but it started leaking again right away. The distributor was replaced by the previous owners for some reason and I wonder if it was a refurbished variety they had installed with a possible problem. Or maybe it isn't the distributor that is leaking. It sure looks like it with oil pooling up underneath where it mounts to the engine block. I also wonder if it is the main seal between the engine and transmission and allows oil to seep around the entire bolted connection point. Has anybody had similar issues or am I dealing with something more severe than I hope?
thanks,
CW
Xuhme
21
Aug 7, 2023 03:40 PM
mattdoc
Mar 14, 2017 12:10 PM
LionSpratt
Jan 29, 2017 11:07 PM
jackoncruzpr
Apr 16, 2015 12:29 PM
Hrddrvs
Apr 11, 2015 11:22 PM
