What are speakers specs for 2001 Civic LX Coupe?
Hi
My Civic's stock sound is crap (only one speaker isn't blown) so I'm finally going to replace my speakers. I am not particularly able to be free enough with money to go get everything professionally done, so I was looking to find speakers on eBay. Problem is, I'm not sure what my speaker specs are. Does anyone know the proper dimensions to get both front and back speakers for a 2001 Honda Civic LX Coupe? Thanks!
Re: What are speakers specs for 2001 Civic LX Coupe?
for a coupe, front is 6.5 inch and rear is 6x9. you need to search around and see which rears would work tho because some are too big and will hit the trunk bars. i would go with some nice infinity reference speakers. and carmedia1.com has good deals on them.
I just installed my system last night, U NEED shallow mount speakers for the door, 6 1/2 in the front, 6 1/2's in the back aswell, this is in my EX sedan coupe may range a bit. but component speakers are nice if you find a nice set of them.
For up front, shallow speakers are (clearly) easier. Some people get away with using MDF spacers to increase the depth, but you might run into problems with the door panel if you go too big.
The 6x9's in the back give you, I believe, ~3.5" to work with. I just replaced mine with a better Pioneer model. Careful what you buy, you can't really use a spacer here unless you're willing to cut a hole in the rear deck and use the covers that came with your speakers.
i have normal 6.5 in my doors, i just have a 1 inch plastic spacer (mdf is not waterproof) and i cut out the plastic lip behind the door panel that is not needed at all. tons of room for the window to roll down and the panel to fit back on.
idk, lol if its just the ex, but a regular 6 1/2 kenwood wouldn't fit, so i got shallow mounts those didn't fit well in the hole, so it took 3 plastic spacers, lol idk lol
maybe it depends on the speakers. i have regular size infinity reference in my ex sedan doors with the 1 inch spacers.
Thank you everyone! I was thinking I might go with infinity; I've heard good things about them. But I'm still a little confused about wattage. Does anyone know how many wats I should look for in speakers? Like, is 120 a good RMS wattage?
rms watts is what to look at. it all depends how loud you wanna go. im perfectly happy with my 60w speakers on a 30w amp. the stock paper speakers are 5w for reference. but at least give the speakers 1/2 of their rms watts when choosing an amp. 3/4 is preferable. do not get aftermarket speakers if you plan to keep the oem honda cd player. it barely puts out 8w per channel so the new speakers will sound like trash being underpowered and you will ruin them. you need an amp, and also a better cd player that supports preamp outputs to connect to the amp.
prolly best to stick with stock speakers then, they will sound better. or if you find any aftermarket ones that are 10-20w rms MAX. maybe some better paper speakers or something. any higher and you will not like the results. there will be very little bass and poor sound.
And, sorry to display my ignorance so obviously, but I can't seem to find the proper dimensions for my car stereo. Would 9.6 x 18 x 2.4 inches ; 4.1 pounds work, or does anyone know of a website that tells you what dimensions to look for when you purchase a car stereo for the dash of your car? I've tried looking it up, but maybe I'm phrasing it incorrectly or something.
hmm never really thought of it. usually they are all standard DIN size. ofcourse you need an aftermarket adapter trim piece to fit the new radio. the stock radio is kinda molded to fit the outer trim piece so you need a new piece. like this.
check local stereo shops, best buy should have something you can look at. otherwise ebay or other place online. i think there are several different kinds so get one that looks good.
All right! Thank you so much! Here's what I went with:
Deck: Pioneer DEH11E SCD Receiver
Speakers (Front): INFINITY 6022i 6-1/2" 2-WAY 360W MAX CAR SPEAKERS
Speakers (Back): Infinity 9622i 6 x 9 2-WAY CAR STEREO SPEAKER 600w PAIR
if you buy the parts from crutchfield, they'll come with the head unit trim ring, the adapter harnesses, and any spacers you need for the speakers. that's all included.
Crutchfield also says that a Double-DIN head unit won't fit in our cars. Which is funny considering the stock deck is double-din, as is my new one, and it bolted right in...
yeah its hard to know everything about every car. you can make almost anything fit with a little work. look at all the parts honda says wont fit certain models and here we are forcing them on lol
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
lilbluecivic
Nov 7, 2001 06:49 PM
