94 DX Coupe Instrument Cluster/tach?
New to the forum and could use some help. I recently acquired a 94 Civic DX Coupe that had a non-working speedo/odometer. I bought a new VSS and the speedo worked fine for about 150 miles then stopped again. When I pushed on the odometer reset, the speedo came back to life. I've repeated this a couple of times, but am thinking I will need to go ahead and replace the instrument cluster to fix it long term. Any other things to try before I do that? Also, if I replace the cluster, can I use one with a tach and if so, can it be from an AT Civic? If I have to replace the cluster, I'd really like to have a tach. Thanks for any info you can provide.
Snax
Aug 12, 2015 10:23 PM
viperGTS
Jul 27, 2015 08:38 PM
RSJ
Jul 23, 2015 11:29 PM
