Is a stiff clutch normal for a Civic?
Old Aug 2, 2009
mntbiknfool's Avatar
mntbiknfool is an unknown quantity at this point
I recently purchased a 1997 Civic with 82k miles and was surprised at how stiff the clutch pedal was. The stiffness of the clutch is almost comparable to that of the muscle cars I used to drive as a kid! This is a little 4 cylinder...the pressure plate shouldn't be THAT stiff should it!
The previous owner said that both the master and slave clutch cylinders had both been replaced recently. I bleed the clutch today to see if it would help anything and noticed a squeal as the clutch pedal was pressed that appeared to come from within the bell housing. The car has set idle for a while and I am beginning to think that the pressure plate has begun to rust! I mean, the pedal resistance should be proportional to the spring resistance in the pressure plate, correct? So the questions I have are:
1) Is your clutch petal easy to push or hard?
2) Has anyone ever had a similar problem?
Thanks for your time.
Jim
Old Aug 3, 2009
monkeydave's Avatar
monkeydave is an unknown quantity at this point
Re: Is a stiff clutch normal for a Civic?
mine is light on 2004 se 1.6 civic
Old Aug 4, 2009
guitarsnroses's Avatar
guitarsnroses is an unknown quantity at this point
I have a '96 civic coupe, and the clutch is very easy to push.
Old Aug 11, 2009
Xirkoz's Avatar
Xirkoz is an unknown quantity at this point
Maybe they replaced it with an aftermarket clutch, its a possibility?
Old Aug 25, 2009
cloume77's Avatar
cloume77 is an unknown quantity at this point
I had 96 ex, 99 Si, and just bought 04 Si and all three clutch felt/feels pretty smooth and easy.
I agree with Xirkoz comment, previous owner had installed aftermarket clutch...
bsmiley
Apr 27, 2015 01:27 PM
aultman1990
Apr 19, 2015 07:14 AM
Guy01
Nov 6, 2001 03:25 PM
