Troubleshoot Wheel Vibration?
Old Apr 12, 2002
klam's Avatar
klam is an unknown quantity at this point
Ok, I recently got new rims for my car and ever since then there has been an annoying vibration that gets worse the faster I go. I can see my steering wheel shake and feel the tires bouncing.
I got 16" rims with Kumho Ecsta Supra 712, 205/55/16.
Originally I thought it was a poor balance job. So I took it back to the wheel shop and explained my problem. They took a look and checked balance. Then they told me to test it out on the highway. I did so and although it was improved, the problem was still present at high speeds.
At "normal" speeds, it's not noticeable. Only when I hit freeway speeds it becomes an issue.
What should I do now?
My friend who has seen this shop suggested that it might be their outdated wheel balancer machine? But I argue that even a mediocre balancer should do a half decent job?
I checked tire pressures and I'm going to use a torque wrench to re-torque my lugs to 80 ft-lbs now.
Any suggestions would be appreciated!
Old Apr 12, 2002
fraga's Avatar
Wicked Moderatuh
Alignment maybe? I dunno.
Old Apr 12, 2002
Eman's Avatar
Eman is an unknown quantity at this point
Have the wheel high speed balanced.
Old Apr 12, 2002
oldskool's Avatar
oldskool is an unknown quantity at this point
same thing happened to my car, Ive put a 17" rim with 205/40/17 on.....it vibrates as soon as i go more than 60, and it pullls really hard to the right
Old Apr 12, 2002
FlexEX's Avatar
FlexEX is an unknown quantity at this point
do you have hub rings for the rims? sometimes when you put rims on without hub rings, the rim isnt perfectly centered on the hub and it causes vibration. if you dont have hub rings, i would recomend putting the rims on yourself and try to tighten the lugs real evenly. make sure the wheel isnt more to one side of the hub.
Old Apr 12, 2002
pogi2k1ex's Avatar
pogi2k1ex is an unknown quantity at this point
alignment
Old Apr 12, 2002
BAK's Avatar
BAK
BAK is an unknown quantity at this point
Klam - take it back to the shop and make sure they installed a wheel/hub adapter on each wheel. My wheels also started to get a shake at about 55 mph and the steering wheel vibrated back and forth from the very frst day I got them. I took the car back to another Discount tire after having my springs put on to get checked out. The guy came back and told me, that there is an adapter that goes inside the rim to mate up with the hub on the car for a perfect alignment. Many cars have a different hub size, so the wheels have a larger diameter hole and they are supposed to use adapters to match the wheel to each cars hub. Otherwise you are relying on the lug nuts to align the wheel to the hub and there is some play in the lugnut holes. Ever notice how tight the center of the steel wheels mates to the hub. Aftermarket wheels are made to fit a variety of different vehicles, so you need the right adapter that will mate with Honda's hub. After they installed the adapters the wheels rode as smooth as possible and no steering wheel vibration. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
FlexEX beat me to it !!!
P.S. if the hub rings are not installed, make sure they get them for you !! Trying to get a perfect alignment with the lugs is nearly impossible. I only felt the vibrations with the speed up over 50-55 mph. Then it $ucked! Now it's FIXED !!!
Old Apr 12, 2002
klam's Avatar
Thanks guys, I'm going to bring it into the shop to check for the hub rings.
Is there any way to tell if they are installed or not externally? Like looking in from the reverse side? Or do I need to remove the wheel to check?
Old Apr 12, 2002
klam's Avatar
Ok, I did some more reading on the topic, and most sources state that aftermarket wheels are lug-centric. So that would mean I would need that shim or whatever it is called adaptor to mate the wheel bore hole to the Honda hub. Where can I get this adaptor piece, only Honda dealer?
Old Apr 12, 2002
BAK's Avatar
BAK
Check with the place that you bought your wheels from, they should have them in stock.
Where did you order your wheels from?
Old Apr 12, 2002
klam's Avatar
Local shop here in Toronto.
Yeah, I'm going to have to go back to them for the third time now... sigh...
Old Apr 12, 2002
BAK's Avatar
BAK
To check if the ring is installed you have to pull the wheel off and look. You can't miss it if it's installed. It's basically a thick black plastic ring that fits into the center of your wheel.
Old Apr 12, 2002
BAK's Avatar
BAK
I was throughly pised off myself !! Unfortunately, I drove it like that for 3,500 miles. I have never even heard that "hub-centric" rings where needed. Here's an article from the Discount Tire site:
Q. What are hub-centric rings; do I need them?
A. Most aftermarket wheels are manufactured with a center hole that will fit a wide range of vehicles. The hub-centric ring is used to fill any gap that may exist between this hole and the vehicle's hub, thus centering the wheel on the axle. If you have vibrations after installing new wheels, chances are hub-centric rings were not used.
Old Apr 12, 2002
02whitey's Avatar
02whitey is an unknown quantity at this point
sup peeps....yeah have fun putting the stock steelies on afterwards...its a bitch i tell you.
I recently installed 17" koning tantrums and the thing shaked really bad so i decided to put on the stock steelies. after i put the stocks back on the two front rims bent and wobbled really bad.
Found out that when you installed the steelies they have to match with the plastic ring which was like impossible to do (tried matching it up like 20 times).
So i just ripped those rings off and now it rides smooth like normal. If you noticed the back rims dont have teh center thing. just rip those things off!!!
lates
Old Apr 13, 2002
VtechChronicle's Avatar
VtechChronicle is an unknown quantity at this point
sounds pretty hardcore whitey...
Old Apr 13, 2002
klam's Avatar
It turns out my vibration problem was a bad balance job by the wheel installer. After taking it back to them and not seeing a huge difference, I gave up on them. Apparently they seemed to be getting annoyed by my multiple visits during the week too!
I took it to another tire shop this morning and the staff were professional, knowledgeable, and friendly. Best of all, they managed to eliminate the vibration.
Old Apr 13, 2002
BAK's Avatar
BAK
Cool... I'm glad someone got it fixed for you. If I wouldn't have gone to another shop, mine would have never gotten fixed either.
Oh yeah, your wheels look good klam ! Good choice !
Old Jun 16, 2002
HondaLuver's Avatar
Its a celebration bitches!
alright, i have those hub centrec rings and nothing happened, i got my tires at tire discount. should i go some where else or what, everbody i saying something diffrent....ahhhh... i hate the vibration... i though it was because i have 18's but it is happeneding to every body, would strut bars help?
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
GritzNGravy
Aug 19, 2015 03:03 AM
alaga
25
Aug 13, 2015 04:42 PM
jedi
Aug 3, 2015 04:26 PM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
