Honda Civic 1992-1995 Disc and Drum Brakes: push rods, pads, calipers and more
Old Jun 29, 2009
Spartanic's Avatar
Spartanic will become famous soon enough
Click on the link to see the complete article with images check it out here: Honda Civic 1992-1995 Disc and Drum Brakes: push rods, pads, calipers and more. Garage411.com
WARNING: Take care not to breath in brake dust. Brake dust is filled with asbestos which causes mesothelioma cancer and or tumor. Mesothelioma destroys tissue and organs and have the potential to spread to other parts of the body. Always clean brake parts with a certified brake parts cleaner before working on the brake system. This will reduce the amount of exposure to asbestos.
All models use front disc brakes. Rear brakes may be either disc type or self-adjusting drum type. Parking brake cable mechanism applies rear brakes.
BRAKE SYSTEM BLEEDING PROCEDURES
Raise and support vehicle. Fill master cylinder to maximum. Check fluid level after bleeding each wheel position. Bleed brakes in following sequence: RR, LF, LR and RF.
BRAKE PEDAL HEIGHT ADJUSTMENT
Loosen brakelight switch lock nut, and back off switch until it no longer touches brake pedal. Loosen brake pedal push rod lock nut, and screw push rod in or out until correct pedal height is obtained.
  • Civic and Civic del Sol AUTOMATIC: 6.5 inches (165 mm)
  • Civic and Civic del Sol MANUAL: 6.3 inches (160mm)
BRAKE WARNING LIGHT
Brake warning light indicates parking brake is engaged and/or brake fluid level is low. To adjust parking brake light operation, turn ignition on. Bend switch plate down until light comes on when parking brake lever is pulled one notch and goes out when lever is released.
MASTER CYLINDER PUSH ROD
Check and adjust master cylinder push rod-to-piston clearance before installing master cylinder.
1. Install Push Rod Adjustment Gauge (07JAG-SD40100) so gauge rod makes light contact with secondary piston of master cylinder.
Ensure gasket is in position when adjusting rod clearance.
2. Remove push rod adjustment gauge from master cylinder, and install gauge onto brake booster. Tighten mounting nuts to specification. Using engine or outside vacuum source, apply at least 10 in. Hg vacuum to brake booster. Check clearance using feeler gauge
  • Civic and Civic del Sol: 0-.016" (0-.40 mm)
PARKING BRAKE
Before adjusting parking brake, loosen equalizer adjusting nut. Start engine, and depress brake pedal several times to set self-adjusting brakes before adjusting parking brake.
1. With rear brakes adjusted, raise and support rear of vehicle. Loosen equalizer nut, and pull parking brake lever up one notch. Tighten equalizer adjusting nut until rear wheels drag slightly.
2. Release parking brake lever. Rear wheels should rotate freely. Rear wheels should lock when parking brake lever is pulled up 6-10 clicks.
REAR DRUM BRAKE SHOES
Rear brake shoes will self-adjust through brake pedal action. No in-service adjustment is required.
STOPLIGHT SWITCH
1. Stoplight switch is located under dash, above brake pedal. To adjust, loosen lock nuts and turn switch until plunger is fully depressed (threaded end touching pedal arm pad).
2. Back off switch 1/4 turn, and tighten lock nuts. Clearance between threaded end of switch body and brake pedal switch contact pad should be about .012" (.30 mm). Ensure brakelights go off when pedal is released.
jessicakaybby
Apr 20, 2015 12:11 PM
