DIY write ups complete. Check them out here.
Old Apr 21, 2009
Spartanic's Avatar
Spartanic will become famous soon enough
Thumbs up DIY write ups complete. Check them out here.
I've completed some write ups on the 92-95 Civic EG. Let me know if you guys see any errors.
EG Civic air conditioning.
EG Civic alignment (camber, caster, toe, etc).
EG Civic automatic tranny removal and installation.
EG Civic drive axles.
EG Civic disc and drum brakes, master cylinder, etc.
EG Civic electric cooling fans.
EG Civic cooling system bleeding and specs.
EG Civic clutch removal and installation.
EG Civic ECU.
EG Civic Emissions Systems. EGR, evap, etc.
EG Civic fuel system.
EG Civic gauge cluster.
EG Civic Ignition System.
EG Civic Intake system.
EG Civic manual transmission.
Del Sol power windows.
EG Civic power windows
EG Civic Steering column.
EG Civic suspension, hub and knuckly, wheel bearing, etc.
EG Civic VTEC system - SOHC D series and DOHC B16A.
EG Civic wiper and washer system.
EG Civic valve clearance adjustments.....newly added!
EG Civic idle speed and mixture.....newly added!
EG Civic specs on just about everything.....newly added!
EG Civic Air Conditioning....newly added!
EG Civic Jacking and Hoisting tips....newly added!
EG Civic engine compression, specs and exhaust system check....newly added!
More updates coming soon...
Old Jun 7, 2009
Spartanic's Avatar
Re: DIY write ups complete. Check them out here.
You guys see any errors? Let me know. thanks.
Old Jun 8, 2009
sl33pyriceboi's Avatar
look good to me. thx for sharing. +1 for you
Old Jun 8, 2009
Spartanic's Avatar
If you guys have any suggestions that I could put on the list then feel free to post here.
Old Jun 8, 2009
daragez's Avatar
daragez is an unknown quantity at this point
nice write ups!....thanks for the share!...
CivicVoz
Apr 16, 2015 08:07 PM
Micks2K1
Dec 6, 2001 07:09 PM
delacampos
Nov 7, 2001 09:18 PM
dubbc
Nov 7, 2001 02:24 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
