1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1991 civic SI rough idle poor mileage
Old Feb 24, 2009
Pistol1583's Avatar
Pistol1583 is an unknown quantity at this point
I have a 91 honda civic SI 1.6 with about 90,000 on the motor. I have noticed a rough idle and poor gas mileage. I did a little tune up with new plugs, new plug wires, vacume lines, air filter, and injector cleaner. I have also noticed when i come to a stop and push the clutch in the cars rpms drop to about 200 and it almost stalls. I also did an O2 sensor about 1 1/2 years ago. I dont think its the gas because i use the same mobile station that i have gone to for years. any tips??
Old Feb 24, 2009
04 Honda Civic's Avatar
Re: 1991 civic SI rough idle poor mileage
I have the same problem https://www.civicforums.com/forums/1...ough-idle.html try cleaning ur IAC. Didnt work for me but maybe it will for you.
Old Jun 27, 2009
sp44's Avatar
sp44 is an unknown quantity at this point
I have the exact same problem on a 92 EX. Anybody find a fix?
Old Jul 2, 2009
Silver06hemic's Avatar
Silver06hemic is an unknown quantity at this point
X2..... also give the TB a really good clean.... run the motor and spray it down whilst raising the revs to keep from stalling. The TB's on any car get gummed up over time... it doesn't take much cause a rough idle. The IAC will cause a constant 'searching' for revs (ie: a rev up and down up and down at an idle) and also in extreme conditions can cause stallouts. It's always good to give it a good spray down as well.
Old Jul 12, 2009
Monotech's Avatar
Monotech is an unknown quantity at this point
Change your fuel filter,cap & rotor. To raise the idle, you have an idle adjustment screw on top of your TB. The wild idle will more likely be due to fast idle valve, just remove it and remove the 2 small phillip screws and remove the cover then tighten up the big plastic valve clockwise and whalah problem fixed.
Old Jul 19, 2009
revr63ed7's Avatar
revr63ed7 is an unknown quantity at this point
A d16a6 doesnt have a thermal fast idle valve to screw the plunger.
Old Jul 21, 2009
sp44's Avatar
For me a new PCV valve fixed it!
mikemc422
Aug 9, 2018 05:41 PM
mattdoc
Mar 14, 2017 12:10 PM
ChristinaVHH
May 10, 2015 03:51 PM
bsmiley
Apr 27, 2015 01:27 PM
Rinzlor
Apr 24, 2015 10:33 AM
